E36 Brake Upgrade and Rim Size Question - BMW Forum - BimmerWerkz.com
Old 05-11-2009, 06:53 PM   #1 (permalink)
hacker is on a distinguished road
Question E36 Brake Upgrade and Rim Size Question
Fellow Bimmer fans…
I need help in determining the correct brake upgrade to go for and the resulting rim size dilemma. I have a 99 E36 328ic, and feel that the brakes are very ‘soft’. I have quite a bit of travel in the brake pedal, and don't feel like the brakes bite hard. Dealer told me I need new Rotors and Pads. I drove an 07 335i the other day, and just barely touching the brake pedal, the brakes bit hard almost jerking me forward! I want that in my E36. Sharp, biting brakes.
The question is, do I simply replace with the same standard equipment, but because it is new it will bite like the 335, or will I never get that sharp stop on my 328?
Turner offers an M3 Brake conversion kit: Turner Motorsport - Item# 325toM3brakes - E36 M3 Front Big Brake Conversion For E36 318i/325i/323i/328i - E36, is that advisable? I read other forums that say it is not easy to install M3 brakes into an E36? Are there any concerns I should have due to the fact that mine is a convertible? Will this really provide the bite I am looking for? This car is not for racing, and am looking at this more from a safety perspective.
I notice that the brake conversion kit requires 17” rims (I have 16” stock), but I do want to upgrade to the 17” Double Spoke original M3 rims anyways. A further question would then be, if I put on the new rims, I have the option of purchasing 7.5inch wide for the front and 8.5inch wide for the rear… do I rather stick with 7.5inch all round? Or 8.5inch all round? As this would assist in tire rotation, or do I stagger them and not rotate. I have also read up that BMW do not recommend rotation?
Thank you!
hacker is offline   Reply With Quote
Old 05-12-2009, 08:11 AM   #2 (permalink)
///E36's Avatar
Car: 1995 E36 318is
///E36 is on a distinguished road
I dont think that you should do such a drastic upgrade, if you say you're after safety the standard oem parts will do just fine, you should also look into a brake fluid change and have a close look at the condition of the brake lines, master cylinder etc.
If you want you could also look into standard discs with a sportier brake pad, however you may find that these will be a bit noisier than standard and will tend to wear the disc a lot quicker.
Possibly get cross drilled rotors, so many options depends on what you want really.
I do think that an M3 brake conversion is overkill for your application.
Hope this helps
///E36 is offline   Reply With Quote
Old 05-12-2009, 08:18 AM   #3 (permalink)
Thank you for the assistance ///E36,
I have heard that cross drilled rotors can warp in winter weather. I live in NJ and will still use the car during the winter. Any advice on rotors / pads that will be used all year round? I do not put much millage on the car, perhaps 2000 a year, but do drive it in all conditions.
Please expand on what you mean by noisier.
Thanks!
Old 05-12-2009, 08:47 AM   #4 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
I think that E46 330i brakes will also fit the E36. The M3 conversion kit from Turner is also a good option. Either staggering or same width all around would be fine -- your choice.
Turkey Fleet Bond Holder
Old 01-21-2010, 06:16 PM   #5 (permalink)
threebackhands is on a distinguished road
Originally Posted by hacker View Post
Fellow Bimmer fans…
Thank you!
Hi,
I have a similar situation and would like to upgrade my 1999 328ic brakes for safety reasons. What did you end up doing?
Thanks.
threebackhands is offline   Reply With Quote
E36 speaker upgrade question ultraviolet353 Audio and Electronics 1 09-15-2004 12:39 PM
question on rim size and tires EzRyde77 3-Series (E46, E90) 5 09-12-2004 07:05 AM
Rim Size ... iantosca 3-Series (E36) 5 08-25-2004 03:27 AM
m3 rim size question...19's?? m3kindaguy M-Series (M1, M3, M5, M6) 1 07-20-2004 02:48 AM
RIM SIZE -- WHICH RIM? kraze0g 3-Series (E36) 5 05-22-2004 03:24 AM
