e36 brake light issue - BMW Forum - BimmerWerkz.com
Old 04-02-2010, 04:34 PM   #1 (permalink)
Paddy_90 is on a distinguished road
hows it goin folks
the problem is the bac brake lights work and then dont work
wen u press the brake pedal it some tyms will work
any ideas
thanks
Paddy
Paddy_90 is offline   Reply With Quote
Old 04-02-2010, 05:52 PM   #2 (permalink)
Have you checked the switch on the brake pedal lever? Maybe it's loose in its mount.
Old 04-04-2010, 07:06 PM   #3 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
^ +5
Old 04-04-2010, 09:00 PM   #4 (permalink)
Car: 1999 e36 323I convertable M-Sport
gscp19842003 is on a distinguished road
"Brake light failure" is either one one of two things - a failed bulb
or a socket assembly that is on the blink (no pun intended). What
happens is that the two little contacts on the sides of the bulb
socket get oxidized and thus start losing contact. The first time I
figured this out, I scraped them with a knife and the socket started
working again. Then I ordered a couple of spare sockets. The 2nd time
it happened (about 6 months later) I simply replaced the socket. This
has happened on my '96 328i and my wife's '94 325i.
"Brake light circuit failure" refers probably to the brake light
switch, located just behind the brake pedal. This switch fails after
100,000 miles, give or take 10K. When this happened to me on my '96, I
ordered the "mechanical" switch replacement part from an online
distributor for about $20. Putting it in was a little bit challenging,
mostly from laying on my back with my head under the dash, etc. When
it failed again after about a year, I ordered the "electronic" version
of the switch for about $27. That was about 3 months ago, so I don't
know about the long-term viability. I have a feeling that the
electronic version will last a lot longer and I think it was what was
originally in the car and lasted nearly 10 years.
The fan in your AC unit going on the blink is related to a capacitor
(electronic component) that fails. I was able to find a web site that
described how to disassemble your AC control unit, pull out the
circuit board and replace this component. I followed the instructions
and mine has worked perfectly since then (about a year ago).
Hope this helps!
gscp19842003 is offline   Reply With Quote
Old 04-08-2010, 05:25 AM   #5 (permalink)
Car: BMW 318i 8v 1995
jrharman is on a distinguished road
I must admit my lights failed my mot and it was the socket assembly.... A simple fix tho:-)
jrharman is offline   Reply With Quote
Old 04-08-2010, 09:54 AM   #6 (permalink)
Glad it's sorted!
Roof issue red light flashing! (and Sat Nav issue too!) doopranal Z3 / Z4 /ZM 0 03-24-2009 06:25 AM
brake light issue rmousir 3-Series (E21, E30) 3 11-12-2007 11:49 AM
E36 Brake Light Sensor? Hamfisted 3-Series (E36) 2 08-11-2005 09:14 PM
HELP, e36 brake light curcuit fault code theogill 3-Series (E36) 4 08-27-2004 07:48 AM
316I COMPACT 1999 E36 Brake Warning Light marcconway 3-Series (E36) 0 08-03-2004 06:04 AM
