E36 BMW Instrument Cluster flickering - BMW Forum - BimmerWerkz.com
Old 03-30-2004, 04:31 PM   #1 (permalink)
mishle is an unknown quantity at this point
Unhappy
Hello to everyone,
I have a 1993 BMW 318i. Recently, my cluster stopped working from time to time. When the car is cold and it is started it works. If the car is turned off after 30 min and then turned back on, none of the cluster gauges would work (gas, heat, rpm, speed), except that they may flicker. I know that when I drive, and I go over rail tracks, it does not get fixed, so it is not like a shortage of cable somewhere. Also, due to that it works when the car is cold, it does not seem to be a fuse as well. If someone could give me at least an idea of where to look to fix it, I would really appreciate your help.
mishle is offline   Reply With Quote
Old 03-30-2004, 05:06 PM   #2 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
The printed circuit board in the instrument cluster expands as the car heats up and shinks as it gets cold. This leads to the failure of solder joints on this circuit board. Some have tried and had some luck reflowing the solder joints on the back of the circuit boards and restoring the use of their guages. Most have had to replace the cluster altogether. And to the forum.
Ben
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 03-30-2004, 06:52 PM   #3 (permalink)
I had the same problem with my dash lights. As the car gets older there's nothing you can do. I've had to resolder lots of wiring because the coating wore off and things were shorting out. Nice car, reminds me of my 318 when I first got it
good luck,
Bry
FS: E39,E38,X5 Instrument Cluster Speedometer nit78 Classifieds Sell & Buy 1 09-14-2009 09:19 AM
Instrument Cluster Wiring spinkb 3-Series (E21, E30) 6 03-06-2005 08:39 AM
Instrument cluster removal shaman97 3-Series (E21, E30) 5 07-01-2004 03:13 PM
new instrument cluster. hodges 3-Series (E36) 7 05-30-2003 07:49 AM
