e36 abs pump prob I think... - BMW Forum - BimmerWerkz.com
Old 05-05-2011, 05:48 PM   #1 (permalink)
Car: 1996 e36 316i auto saloon
skinbar is on a distinguished road
Wink e36 abs pump prob I think...
hi there
pulled up outside pub to do gig with my band,turned off ignition of the car, noticed buzzing coming from front end.lifted bonnet listened. Under battery tray there's a motor with pipes coming out of it,this was buzzing away. Has been making a funny groaning noise on start up for a while which either goes away or persists but not effecting car as such, tried starting then stopping car had no affect still buzzing away, so decided to take battery terminal off so I would be able to start car to get home. Had to leave it buzzing away once home as no spanner to remove terminal so drained battery.Also ABS light now on.
got the right size spanner now,LOL....
Any suggestions appreciated as really no got a clue
skinbar is offline   Reply With Quote
Old 05-06-2011, 08:53 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Replace it LOL
Old 05-06-2011, 06:00 PM   #3 (permalink)
OK.I'm sorry new to BMW so now I've identified what it is and best way to proceed without doing more damage to car, like no brakes, which in this case I'm told is disconnect wiring so doesn't waste battery......
so then will look into getting replacement as need car to be on the road.
Old 05-07-2011, 08:02 AM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Try pulling the abs fuse out...
Old 05-09-2011, 03:02 PM   #5 (permalink)
ABS pump prob
Ok, did that fuse no.38 for anybody else who's stuck in the same position.
say's on fuse box fuse's 10,21,and 38 first two motor kept running so all good now.will keep that spanner on board just in case....
so next question is once purchased new or reconditioned unit can i replace myself or is it specialist job.
also any idea what the groaning noise is,was thinking air con as this seems a bit erratic in responding to controls unless engine warmed up once heater working seems to stop but noise starts and stops wierd
Old 05-09-2011, 04:20 PM   #6 (permalink)
jimmythepie's Avatar
Car: 98,328i
Originally Posted by Dabsy View Post
Replace it LOL
careful Daz people will begin to believe that you are me, don't laugh it's happened before, no seriously it really has. Nice to see you still here
jimmythepie is offline   Reply With Quote
Old 05-09-2011, 04:23 PM   #7 (permalink)
Car: 98,328i
hey skinbar must be quite a struggle getting a set of bagpipes in the boot, all the best Jimmy
Old 05-10-2011, 02:17 PM   #8 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Air-con wouldn't groan "as such" but not get cold...
Replacing the ABS unit IS easy, just follow any "Bleeding procedures"...
It could be that the fluid just needs renewing, try the easy options before spending many £££'s on it...
DAZ
Oil Pump Gasket And Oil Pump Bolts Cambridge 5-Series (E12,E28, E34, E39, E60) 1 05-16-2005 05:18 PM
Fuel Pump Prob...any Suggestions mosyslack 3-Series (E21, E30) 5 11-23-2004 07:26 PM
XM prob El Presidente Audio and Electronics 7 07-02-2004 05:45 PM
E-30 head prob. Need help please mebyon 3-Series (E21, E30) 0 05-03-2004 08:47 AM
Another OBC Prob kiwiphil 3-Series (E36) 3 03-05-2004 01:17 PM
