E36 328i Bad Misfire, Hard to Start - BMW Forum - BimmerWerkz.com
Old 02-19-2009, 03:20 AM   #1 (permalink)
Car: 1996 E36 328i Coupe individual
Shanew1983 is on a distinguished road
Hi guys,
Im new to this site and would like your help. Ive a 1996 328i coupe, i recently put a new engine in well for the 3rd time to be honest. everything was fine for a day or two now all of a sudden it take longer to crank than normal, theirs a slight misfire when cold just as you push the Accelerator. It drives ok for about 5 mins till it heats up then just goes into a complete spamm. its loses all power and is misfiring continously all the way until around 5000rpm and then might lift slightly. Ive changed the coils with another set i had from previos engine and also the airflow sensor. Any ideas what might cause this irractic behavior.
Many Thanks
Shane
Shanew1983 is offline   Reply With Quote
Old 02-19-2009, 11:14 AM   #2 (permalink)
jeewing7's Avatar
Car: 1994 Alpine 325iC
jeewing7 is on a distinguished road
There are so many possibilities but coolant temp sensor comes to mind for the bad performance at operating temperatures. This appears to be a thermal problem where the ECU is getting bad information but not enough to set a CEL.
Did you convert this to OBD1 and if so did you swap the temp sensor and, immsmc, the oil temp sensor? There are two sensors that use the exact same plug and are easily crossed. You may want to refer to the bentley to be certain. I don't remember the specifics.
jeewing7 is offline   Reply With Quote
Old 02-19-2009, 02:45 PM   #3 (permalink)
Tryed everything today, changed the inlet manifold, 6 more coils, coolant temp switch, everything bar what i should have changed in the first place, as it was delaying starting. Turned out to be a faulty crank shaft sensor, i swaped it from my old engine and bang it started perfect and is now running 100% no misfire,s nothing.
Thanks again
Old 02-19-2009, 03:01 PM   #4 (permalink)
Glad you solved your issue!
Old 04-21-2009, 11:56 PM   #5 (permalink)
donleycott is on a distinguished road
Faulty Crank Sensor - Any Codes
Did your BMW display any codes or a CEL when it was misfiring?
donleycott is offline   Reply With Quote
Old 04-22-2009, 12:29 AM   #6 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
glad to hear you got it running
1992 318i Coupe parts car
I am Captain Obvious
Old 04-26-2009, 09:40 PM   #7 (permalink)
Deuceakc is on a distinguished road
ive goot the same problem with my 328is i just bought, here the crank sensor was ganked at the lot that i bought it from before i bought it!!! anyways i cant find where it plugs into! i know where it mounts on the block but i cant find where the lil bastard plugs into the wire harness!
anyone have any pictures??
sorry for the thread jack butt...
Deuceakc is offline   Reply With Quote
320D hard Start jaweed New Members Check In 2 11-25-2008 03:40 AM
1986 325es SMOKES, HARD START, BAD IDLE !!FIX!! kenika65 3-Series (E21, E30) 1 03-22-2007 10:29 PM
Cornering Hard In Bmw's? Bad? BMW-ATI 3-Series (E36) 12 04-18-2005 11:45 AM
'89 325i Hard Start 1989BMW325i 3-Series (E21, E30) 2 02-25-2005 09:39 AM
is it bad to drive your car hard? RPM question... ultraviolet353 3-Series (E36) 29 08-11-2004 02:25 PM
