E36 318i engine change to 318is? - BMW Forum - BimmerWerkz.com
Old 03-07-2010, 11:30 AM   #1 (permalink)
Car: E36 318i SE
calvs79 is on a distinguished road
Hi all,
i have a 318i and have blown the engine big time! is it possible to fit a 318is lump with little ease or is there a lot of things that i would have to change as well???
any replys and most thankful
calvs79
calvs79 is offline   Reply With Quote
Old 03-07-2010, 11:33 AM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Your "Cars" field says "e36 318i SE (M44)" ... if your car already has a m44, then swapping another one in it's place will be as simple as unbolting it and bolting the new one in; just make sure it's a m44 and not a m42 as the wiring is a bit different, though nothing too horrible.
Old 03-07-2010, 11:37 AM   #3 (permalink)
Car: E36 318i SE
yeah my bad i put m44 when i first got the car, but its only the 8v model which is the m42 i think im not to sure and i cant find how to change my profile to amend it ...
Old 03-07-2010, 11:41 AM   #4 (permalink)
Car: E36 318i SE
i think i have a m40 lump???
Old 03-07-2010, 01:40 PM   #5 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Yup either a m40 or a m43 is what you have.
Both the m42 and m44 are 16 valve motors (basically the 'is motors you are looking at swapping).
Out of those two, I would probably take the m44 if I had the choice (a bit more displacement and a bit more torque and it has a MAF instead of AFM).
As for the swap: I am not really sure if the 16v engines will bolt up to the transmission you have now (definitely something to look at), but aside from that since the e36 came with the motors you are looking at swapping in, you just need the basics: mounts, wiring harness and ecu. I can't imagine it being too difficult
Difference between E36 318i and 318is tonysticks 3-Series (E36) 27 03-01-2011 07:38 PM
1993 318i E36 M42 Engine Rough Idle zagitazz 3-Series (E36) 0 08-31-2008 10:28 PM
DIY Pictorial Guide For E36 318i 318is 318ic 318ti M42/M44 Spark Plug Replacement Delmarco FAQ's and DIY's 10 07-08-2008 10:42 PM
Verifying Engine type on 1994 318i E36 - I NEED HELP GUYS! hyper_cool 3-Series (E36) 5 08-29-2007 01:57 PM
E36 318is Coupe (m42 Engine) munky999 3-Series (E36) 3 11-23-2004 03:05 PM
