Originally posted by Autotechnica@Jul 21 2004, 01:08 PM |
Thats correct, for example when I am driving with 4th gear and engine rpm anywhere over approx.3000 and I am letting off the throttle, the engine rpms starts to go higher all the way to 5000 rpms, and it will keep the rpms there unless I push the pedal for 2-3 times. I have checked the throttle body its ok, and the throttle spring is quite heavy work. Cable is fine also.
And the funny thing is that it will do this over rpm only when driving with gear on, not when I am idling or standing still and pushing rpms over 4000. The engine gets fuel, even it is not supposed to get it or something else (electrical failure, who knows). No difference if the engine is hot or cold and it is starting and idling normally. I was wondering if the throttles electrical censor is broken etc...
