Hi there everyone - new to this forum, but am posting in the hope that some of you maybe able to help me with a problem with my E36 316i SE with 100,000 on the clock that I recently bought.
I did have a lot of judder coming from the front end and through the steering wheel during braking, which turned out to be warped discs. I changed discs and pads and that solved that problem.At the same time I had the rear bushes and suspension top mounts replaced as they were knackered.
However, what I'm finding now is that as I'm driving I can feel some play and vibration coming from the front end. It is more noticeable on rough or worn tarmac or bad roads. It almost feels like there is some slight play somewhere in the steering setup which I can feel through the steering wheel.
On smooth roads it is fine .Almost as if something has worn and there is some play in amongst that lot somewhere. Not enough to cuase any real major concern but enough for me to want to solve it.
The other thing is that sometimes, but not always, I can grab hold of the tops of the front wheels and pull them towards me. If I said 1 - 2mm of play then that would be realistic. Wheel nuts are tight. Sometimes they are fine, and it's the same for both sides.Its like the whole wheel and hub assembly moves.
I recently had the car MOT'd and it passed with no problems. I asked the garage to have a look due to the above, but they said that apart from some wear in the steering rack everything was fine. When I entioned about the give in the wheels they mentioned something about free floating suspension. They aren't a BMW dealers but work on them all the time and do excellent work. I've had my cars serviced there for years with no problems.
I kind of drummed up a possible cause list, but probably am way off the mark...
Wheel bearings
Front suspension top mounts worn
ball joints on front end
shocks worn and need replacing
Umm, and thats about it. Anyone got any advice
Regards
Chris
