e36 1998 m3 valve cover - BMW Forum - BimmerWerkz.com
Old 06-21-2006, 04:01 PM   #1 (permalink)
cabrit is on a distinguished road
would a 99 valve cover fit a 1994 m50 engine without any problems
i know for a fact that i have to change the valve cover gasket what other problems will i encounter.i have the valve cover and the coils since they are different i want to know if they would actually improve the engine or i t would be a waste of time. any help would be appreciated
thanks
cabrit is offline   Reply With Quote
Old 06-21-2006, 04:04 PM   #2 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Nope. 93-95 would fit yours.
Just look at the valve cover. The hole for the location where you pour oil into the engine is located above cylinders 1 or 2 and yours has it above 5 or 6.
Old 06-21-2006, 05:32 PM   #3 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
All the heads (vanos heads) are the same, the valve cover should bolt in the same. Im not sure though if the oil filler hole makes a diffrence.
-Serge
theruss1an1 is offline   Reply With Quote
Old 06-21-2006, 07:16 PM   #4 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
I know all the vanos heads are the same, but if he switched to the obdii version of the valve cover then wouldnt he switch the ifller hole over to the obdii location. In that case then wouldnt he then be required to purchase the obdii plastic cover than goes on top of the valve cover?
If the new location of the oil filler hole is now in the obdii location would it have any effect other than engine oil being put in at a slightly different location?
Old 06-21-2006, 08:30 PM   #5 (permalink)
Car: Needs momentum
Dont think so.
Well in the end.. the oil goes to the same place.
-Serge
Old 06-21-2006, 11:24 PM   #6 (permalink)
the coils look something like this
i would have to purchase the plastic cover.different than that of the m50/s50. also because of the oil filler the only reason it cant fit now is because of the gasket of the m50. the m50 and s52/m52 engine takes a different gasket due to the fact that the obd II valve cover is abit different in the back other than that everything is ok. i am going to buy the s52 gasket to see if it works if it does not work i guess i am going to sell the gasket which would be brand new, the valcover, the vent pipe, attached to it the coils(6) and the studs to screw in the ignition coils.i hope it works if not what a waste
Old 06-21-2006, 11:46 PM   #7 (permalink)
LYFE SUCK5
Ivan's Avatar
Car: 2008 Infiniti G35
Ivan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant future
Send a message via AIM to Ivan
cool so once i get my m50 in my car i can rice it a bit and get it bmw m power covers?
Ivan is offline   Reply With Quote
Old 06-22-2006, 01:28 PM   #8 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Ivan, ban yourself.
Old 06-22-2006, 02:17 PM   #9 (permalink)
LYFE SUCK5
Ivan's Avatar
nah
Old 06-22-2006, 02:45 PM   #10 (permalink)
The Messican
MiguelACA's Avatar
Car: 2000 2.3 Z3
MiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond reputeMiguelACA has a reputation beyond repute
Send a message via AIM to MiguelACA
Ivan, ban yourself.
lol
A morning of awkwardness is better than a night of loneliness
MiguelACA is offline   Reply With Quote
E36 NEW SHIFT BOOT 1992 thru 1998 318 325 ect. customshiftboot Aftermarket Parts 0 11-30-2005 08:33 AM
1998 318is - Adjusting valve gear? alex_318is 3-Series (E36) 3 09-18-2005 04:48 PM
95 M3 Valve cover zinger Looking For 0 09-14-2005 07:04 PM
Painting the Valve Cover detour54 3-Series (E21, E30) 21 01-13-2004 04:15 PM
Valve cover cracked. Batunas 5-Series (E12,E28, E34, E39, E60) 1 12-11-2003 08:55 AM
