It started about 3 monthes ago i filled up with fuel drove 20 miles parked up for 30 mins or so got back in car and it would not start so i left it!I tryed again couple of hours later and it was fine started on the button.Then about week later same prob cut out while at a junction low revs!would not start again so i turned over in gear and fired but holding back on power!parked up went out to it next day and fine again done 50 miles in it problem came back again would not start on key unless you let it stand for hour or so but will fire up if you turn over in gear!this prob has got worse and worse but still keeps on going!Yesterday i drove 5 miles then for some reason it would not rev over 2.5k idled fine and started on the key!went out to it today and its fine again???
Ive checked tank fuel filter main fuel filter had all earth straps off and cleaned no air leaks (split hoses etc)no warning lights can anyone help me Please?
