E-Brake Adjusting????? - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 09-18-2005, 11:08 PM Thread Starter
Red93B3M2W5i is an unknown quantity at this point
Send a message via AIM to Red93B3M2W5i Send a message via Yahoo to Red93B3M2W5i
Can anyone point me in the right directions with links or pictures or just advice on how i go about adjusting my E-brake. It is like completely loose. I pull it all the way up and almost nothing happens at all and it is not very noticealbe at all? Any input would be greatly appreciated...Thanks
Red93B3M2W5i is offline
post #2 of 5 (permalink) Old 09-19-2005, 09:33 AM
thekid's Avatar
thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute
Pull the trim thing around the e-brake lever up. I was able to do it with my fingers. Then tighten the bolts that are on either side of the lever, make sure you tighten both the same amount. If you are tightening the bolts a whole lot, for instance several dozen turns, or the bolts do something like run out of room, then there is a problem somewhere else. Once it is tight and it does work like it is supposed to, get onto a fairly flat surface, but one where you will still roll. Then take your foot off the brake so that the car rolls ever so slightly, then pull the e-brake. If one side of the car feels like it... bounces or feels different (hard to describe) then you need to tighten the bolt a little bit on that side of the e-brake handle. Repeat until it feels normal. This will make sure the e-brake is being applied evenly on both sides. I think pelican parts might have a DIY with pictures on how to do this... lf you are confused.
thekid is offline
post #3 of 5 (permalink) Old 09-19-2005, 09:51 AM
Storamin's Avatar
Storamin is an unknown quantity at this point
http://www.pelicanparts.com/bmw/tech...Adjustment.htm
Along with the inside handbrake adjustment cables, you might also need to adjust the parking brake shoes. I had to, as the shoes will start to wear.
Storamin is offline
post #4 of 5 (permalink) Old 09-19-2005, 12:04 PM
MalibuSean is an unknown quantity at this point
The pelican article is right on. But in addition, my manual says that when you back off the sprocket, it should click 18 times for a 3 series, but 8 times for an m3. I'm pretty sure these numbers are right. I followed the procedure, and the e-brake works great now. Good luck.
-Sean
MalibuSean is offline
post #5 of 5 (permalink) Old 09-19-2005, 12:28 PM Thread Starter
Thanks a lot everyone, I appreciate it...I will get into this later this week...Thanks though
Parking brake not releasing GnarlyCow 3-Series (E46, E90) 13 07-29-2004 03:39 AM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
