e-box, cpu - BMW Forum - BimmerWerkz.com
Old 10-02-2003, 04:56 PM   #1 (permalink)
bmgmde36 is an unknown quantity at this point
i need to install a new cpu. had water damage from a car wash! can anyone help?
bmgmde36 is offline   Reply With Quote
Old 10-02-2003, 06:16 PM   #2 (permalink)
Walker is an unknown quantity at this point
that sucks a nutball.... sueing the carwash or what??
Walker, Texas Ranger....from New York..
Walker is offline   Reply With Quote
Old 10-06-2003, 01:25 AM   #3 (permalink)
ex owner/admin
Furious's Avatar
the "cpu" or dme or whatever you wanna call it is located behind the rubber kickwall in the rear-passenger side of the car. remove the screw caps, remove screws. peal back rubber, open pannel, and pull out the dme. be carefull of what you are pulling at and what you knock . the dme should slide out of its harness easily if you un-latch it properly. if you need more help with this you can always reply to this or your best bet is to maybe pick up some sort of maintainace manual.
Old 10-06-2003, 05:41 PM   #4 (permalink)
Hamann 325i is an unknown quantity at this point
umm is the engine cpu the same as an ECU?
Hamann 325i is offline   Reply With Quote
Old 10-06-2003, 07:09 PM   #5 (permalink)
Eggrolled211's Avatar
Eggrolled211 is an unknown quantity at this point
Hey look carefully through this forum...FAQs etc...it's shows steps and pictures how to etc....removing the CPU etc.
<img src='http://l00062.myspace.com/00062/50/89/62019805_m.jpg' border='0' alt='user posted image' />
Eggrolled211 is offline   Reply With Quote
Old 10-06-2003, 07:11 PM   #6 (permalink)
Here.... http://www.zync.com/chip/
Old 10-09-2003, 03:27 PM   #7 (permalink)
L337E46's Avatar
L337E46 will become famous soon enoughL337E46 will become famous soon enough
Once you pull your DME (It's also called the ECU) you need to replace it with another unit. When you put the new unit in, depending on which model E36 you have the ECU needs to be programmed by either your dealer or an independent BMW mechanic equipped with a modic/DIS. Cost to program? Around $50-$60. How much is a New DME? Grab your ankles it may run anywhere from $600 on up... BTW, who told you that your DME was shot???
General, Troll Warfare Center: Task Force Troll/Founder BMW FORUMS 3.1415926535897932384626433832795 CLUB/Board Member Brotherhood of Huzzah/Board Member Troll Assassin Board/Board Member W00t! Club/Campaign Director Yanosh for President/Founder L337 Flash Club/Founding Member BMW Forums V1 Club/ BMW-Forums Badger Badger Badger arrgggghhhhhh club
L337E46 is offline   Reply With Quote
E36 m3 sagging glovebox. Fixed. Mostly. 4evrwyntr 3-Series (E36) 9 09-11-2005 11:36 PM
AIR BOX DEBAFFLE *help please* White e36 dude 3-Series (E36) 6 09-10-2005 03:17 PM
