Door Won't Open From The Outside? - BMW Forum - BimmerWerkz.com
post #1 of 11 (permalink) Old 04-04-2005, 09:35 PM Thread Starter
lavalva is an unknown quantity at this point
My driver's side door doesn't open from the outside. I took it apart tonight and I think I can tell what's wrong with it, but I'm gonna struggle to explain.
It looks like there is a little cylinder that goes into this "ring" and then when you pull on the outside handle, it can't pull it back far enough because the metal has been worn a bit.
Does anyone have a clue as to what I'm talking tabout? The door opens from the inside, but not the outside. If you know what I'm talking about, do you know what it's called so I can order it? lol... Thanks for the help.
lavalva is offline
post #2 of 11 (permalink) Old 04-04-2005, 11:54 PM
kassper is an unknown quantity at this point
take some pics, that will probably help
kassper is offline
post #3 of 11 (permalink) Old 04-05-2005, 07:22 AM Thread Starter
[snapback]325785[/snapback]
I can't get a camera in there or I would have.
lavalva is offline
post #4 of 11 (permalink) Old 04-05-2005, 07:39 AM
mmclaren is an unknown quantity at this point
LOL
i had the same problem?? oops i mean i have the same problem. Its the latch that goes next to the door handle on the inside. I had a picture but lost it :P its made of discast and is about 4-5 cm long, so remove the trim which holds the door in place and seals the window and have a look in "provides light makes it easier" and i would bet its the same problem. To what i know there is only 1 way of fixing it, and thats been from other forum users and thats with a new door handle assemble. I am buying one out of a junk yard since i dont care about the new key design it comes with, since i use beep beep locking.
hope that helps
mmclaren is offline
post #5 of 11 (permalink) Old 04-05-2005, 08:15 AM Thread Starter
I had the door panel off, that's how I figured out what it was... Is there anywhere I can find a diagram of the internal parts?
Originally posted by mmclaren@Apr 5 2005, 08:39 AM
LOL
hope that helps
[snapback]325873[/snapback]
lavalva is offline
post #6 of 11 (permalink) Old 04-05-2005, 09:13 AM
Eggrolled211's Avatar
Eggrolled211 is an unknown quantity at this point
It happen alot during the cold weather on mine...I use elbow grease...bang the handle a couple times and it comes loose...I use grease or WD40 sometimes......okay so far hasn't gotten stuck for many months now......I dunno...gL
<img src='http://l00062.myspace.com/00062/50/89/62019805_m.jpg' border='0' alt='user posted image' />
Eggrolled211 is offline
post #7 of 11 (permalink) Old 04-05-2005, 09:38 AM Thread Starter
[snapback]325898[/snapback]
Yeah, it's not stuck... I tried, and was successful more often than not a while ago, but now it looks like it just doesn't pull the pin far enough.
lavalva is offline
post #8 of 11 (permalink) Old 04-05-2005, 03:49 PM Thread Starter
Does anyone know where I can find a diagram of inside the doors?
lavalva is offline
post #9 of 11 (permalink) Old 04-05-2005, 05:52 PM
arabdelight is an unknown quantity at this point
Send a message via AIM to arabdelight Send a message via MSN to arabdelight
http://www.realoem.com/bmw/partgrp.do?mode...700&hg=41&fg=40
This is the diagram for the front doors of a 1992 325i. If your looking for a different model check the site they have diagrams for almost everything.
arabdelight is offline
post #10 of 11 (permalink) Old 04-05-2005, 06:17 PM
abemcclellan's Avatar
abemcclellan is an unknown quantity at this point
dude i had the exact problem with mine. i had to order a new door latch assembly from the dealership. just the part was around $280. Then i took it to my bmw mechanic and he did the work for me, because i absolutely hate getting inside the door to do those jobs. Its a good thing i didn't do it either because my mechanic had to pull half of the window completely out to get to the inside and take the assembly out. because mine is a coupe. but good luck man.
abemcclellan is offline
post #11 of 11 (permalink) Old 04-05-2005, 06:22 PM
Do not know about the E36, but on my E32 there are two Bowden cables (twisted wire with a hook at each end), one for inside door handle and one for outside door handle and when I lost ability to open door from inside it was a broken Bowden cable.
Bear is offline
Door will not open from inside or outside...HELP!!! tylset 5-Series (E12,E28, E34, E39, E60) 21 01-26-2016 10:18 PM
Can't open my doors maci4life 5-Series (E12,E28, E34, E39, E60) 11 06-24-2011 08:11 PM
Keyless Trunk to Open dberger 5-Series (E12,E28, E34, E39, E60) 0 07-15-2004 08:57 AM
i cant open my trunk!!! 88325i 3-Series (E21, E30) 6 04-30-2004 11:18 PM
My door won't open Eggrolled211 3-Series (E36) 5 12-03-2003 11:23 PM
