Door Locks Dead, please help! 96' 328i E-36 Sedan.. Door Locks Dead, checked and replaced fuses, replaced Drivers Side Actuator. Still completely dead!
The door locks (front-rear-trunk) gradually went dead if this helps, intermittent, sometimes and now, not at all!
Relay Central Locking Unit maybe? I believe its on the passenger side kick panel above speaker but have not checked.
I just don't seem to be getting power through the system...
Any help would be welcomed at this point.
BTW: If you are replacing the Drivers Door Actuator, do not remove the door lock and or hinge and linkage unless it is really necessary. You can remove the actuator from inside the door, snaps off... snaps on.
New Member Jonathan in Central Florida
JEV1A ... pics coming soon |
