DOOR JAM - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 03-07-2004, 04:59 PM Thread Starter
tisinotjon's Avatar
tisinotjon is an unknown quantity at this point
Send a message via AIM to tisinotjon
MY passenger door is jammed n wont open from inside or outside.... what should i do? to resolve to problem
tisinotjon is offline
post #2 of 6 (permalink) Old 03-07-2004, 05:18 PM
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
1st - ahh haahahahahahahah
2nd - either your going to have to try and remove the inside door skin from inside the car, or get a slim jim tool to pull the lever manually from outside the car, (sorta like guys that break into cars do). your controls might have became unattached from the levers, or possibly brok apart the mechanism so you won't be able to use the handles.. can't garuntee it wil work, but it is a start and a damn good one... 1st try getting the panel off the inside door.... Remove the screws, and the bottom just clips on, if you can pull you will get it off....
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='
target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='
bimmerfan620 is offline
post #3 of 6 (permalink) Old 03-07-2004, 06:08 PM
bmwtech332ti is an unknown quantity at this point
one possible fix is to lube the door latch but you will have to get the door open first. I have seen this alot, I know it sound retarted but I am a tech at bmw and I know what I am talking about. The way I usually get the door open is pull latch from inside and push as hard as you can. If this doesn't work let me know.
bmwtech332ti is offline
post #4 of 6 (permalink) Old 03-07-2004, 06:22 PM Thread Starter
tisinotjon's Avatar
alright i got the door to open from the inside but ITS HARD and i think its gonna brake when i dont it... BUT IT STILL WONT OPEN FROM THe OUTside Got any ideas why this would be happening?
post #5 of 6 (permalink) Old 03-07-2004, 07:03 PM
Mesverrum is an unknown quantity at this point
i actually have a similar problem with my passenger door, the inside level needs to be pulled pretty hard (my friends always think i locked them in the car and that they will break it if they pull on it) and the outside doesnt respond out at all. I just got my locks redone on my drivers side door so i took a good look at how things are supposed to be connected and im going to be taking the passenger side door apart to make sure its all hooked up correctly and that none of the bits are worn out/bent. I just need to buy a few torx drivers or whatever they are so i can get the passenger side off.
Mesverrum is offline
post #6 of 6 (permalink) Old 03-07-2004, 07:44 PM Thread Starter
tisinotjon's Avatar
I fixed it the problem with good old Wd-40 thanks
