Door Double Locks - BMW Forum - BimmerWerkz.com
Old 05-14-2004, 05:38 PM   #1 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
hey guys, my car(92 325i) has no alarm, so when i lock the doors manually( push them down) they pop back up! then i push em down 2nd time, they stay locked, same goes for when i lock from the outside, unlocking no prob, locking is wierd, any info would be much appreciated...
Old 05-14-2004, 06:07 PM   #2 (permalink)
Defector
El Presidente's Avatar
no idea, but my inclination would be a short or problem with the locking mechanism. Is it EVERY time, or most of the time?
Old 05-14-2004, 06:38 PM   #3 (permalink)
General Chaos
Car: ///M3,Corolla
Everytime
Old 05-14-2004, 06:43 PM   #4 (permalink)
Defector
probably a short or a bad relay. Don't know much about the locking mechanism, so I really don't know what to say.
Old 05-14-2004, 07:37 PM   #5 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
Does the same thing on my 5 series.
Solution, lock the doors from the outside or hold the lock down for a few seconds.
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline   Reply With Quote
Old 05-16-2004, 12:07 AM   #6 (permalink)
TeeUp's Avatar
Car: 2002 X5 3.0i and 2007 X5 3.0i
TeeUp is an unknown quantity at this point
i would suspect one of your front-door (master) lock actuators. you may have to open your front door trims and check on the linkage of the actuator to the car locks. it may be loose. it should be set in a way that when it is locked the actuator's link goes all the way inside (or the reverse). if the link stops halfway, it bounces back open.
i dont know if i am making enough sense,,,, ill try to get some illustrations.
TeeUp is offline   Reply With Quote
Old 05-16-2004, 04:56 PM   #7 (permalink)
TeeUp's Avatar
here.. http://auto.consumerguide.com/auto/used/re...dex.cfm/id/2117
it says that if the central locking system unlocks itself after being locked or locks itself after being unlocked, the actuators could be defective or the trunk lock may need to be adjusted.
Old 05-16-2004, 05:00 PM   #8 (permalink)
TeeUp's Avatar
i am not quite sure about this.... if the problem is just the adjustment of the locks where the actuator rod is linked, forcing it down might just wear your actuators (bigger problem).
Door Locks Duge 3-Series (E36) 3 07-20-2005 07:03 PM
Door Locks Gone Haywire! ///M Power 5-Series (E12,E28, E34, E39, E60) 8 05-19-2005 12:26 PM
All My Locks Are Toasted Smooth Criminal 3-Series (E21, E30) 4 01-08-2005 10:52 AM
Did all E30's come with Pwr Locks? 2001 Yellow 3-Series (E21, E30) 1 03-28-2004 04:40 PM
1994 740i Door Locks agsiegel 1,6,7,8 - Series and Mini Cooper 3 08-06-2003 08:44 PM
