Doing your Own brakes - BMW Forum - BimmerWerkz.com
Old 03-21-2006, 05:10 PM   #1 (permalink)
k2c69n's Avatar
k2c69n is an unknown quantity at this point
I will be needing some new rotors and pads for the front and back.
Has anyone here done their own brakes and if so, how difficult is it, and what things should I look out for.
I have done brakes before, not on a bmw. Just curious if anyone has any pointers. I really do not want to bring it to a mechanic again. They were estimated around 700-800 to do them. I gave them enough of my money for now.
appreciate your insight
*If your not living on the edge your taking up too much space*
'98 328is
k2c69n is offline   Reply With Quote
Old 03-21-2006, 05:16 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Brakes are super easy to change on BMW's you will need a caliper tool to depress the caliper, a 6mm allen key, a 7mm allen key (prefer socket style myself) a1 16mm (or 17mm) 6 point socket and breaker bar, and a hammer to knock the rotors off the hub. Use a good high quality bostic lube paste (like anti-seize) (and don't use that brake quiet spray crap) You will do fine
Come see me at MySpace
Old 03-21-2006, 05:37 PM   #3 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Where do you get a "caliper tool," and what does it look like?
Lindsay fan club member.
Old 03-21-2006, 06:22 PM   #4 (permalink)
Avlany's Avatar
Avlany is an unknown quantity at this point
Send a message via ICQ to Avlany
I rented it in AutoZone
Dont piss me off. I am running out of places to hide the bodies
<img src='http://members.dslextreme.com/users/avlany/images/BMW%20banner.gif' border='0' alt='user posted image' />
Avlany is offline   Reply With Quote
Old 03-21-2006, 07:57 PM   #5 (permalink)
Get yourself a Bentley service manual. Either the paperback version or download the .pdf version (94mb?). All this stuff is explained in there. The allen screw that retains the rotor is 5mm. You just need something to spread the old pads apart and compress the caliper piston down so the new pads will slide on easy. Clean the replacement rotor very well with brake cleaner to cut the anti-corrosion film off before installing it or you'll trash your new pads. Use a quality brake pads and rotors, like Axxis Ultimates or Akebono ProActs (Tire Rack), they are both dust free. If your brake service light is on you'll need to replace the brake wear indicator of the offending wheel (either the left front or the right rear wheel....). But if the brake light is not on you should be able to reuse the existing brake wear indicator. Use JackStands when working on the car, not just a hydraulic jack. Good luck.
Mike
Hamfisted is offline   Reply With Quote
Old 03-21-2006, 08:17 PM   #6 (permalink)
tomctx's Avatar
www.bimmerzone.com/parts-special-brake.htm
Running a sale on front and rear brakes. If you don't have allen sockets, a torx bit socket will work.
Old 03-21-2006, 10:31 PM   #7 (permalink)
Da Prophecy is on a distinguished road
Anybody have any opinions on the break kit in the above post?
If so what rotors and pads do you suggest and where from?
Kyle
Da Prophecy is offline   Reply With Quote
Old 03-22-2006, 06:06 PM   #8 (permalink)
325isBaby's Avatar
Car: 2005 330xi
torx and allens ARE NOT the same thing
Torx
Allen
DO THE LOOK THE SAME?
This is the pad spreader you need (can get at harbor freight tools, checker maybe)
Old 03-22-2006, 08:30 PM   #9 (permalink)
tomctx's Avatar
[QUOTE=325isBaby]torx and allens ARE NOT the same thing
No they are not the same, but the Torx bit will work in an allen head, if you don't have the allen handy. Done it many times, try it.
Like someone said, rent the spreader at Autozone, use it, then return for full refund. I would say use a big screwdriver as a pry bar to push the piston back in, but that would probably upset some people.
Old 03-23-2006, 12:25 AM   #10 (permalink)
325isBaby's Avatar
Car: 2005 330xi
If you depress the piston too quickly you risk ruptering seals in the brake system so if you want to cause damage to your brake system, right tools for the right job...Y screw things up when it could be done right the first time.
Old 03-23-2006, 12:49 AM   #11 (permalink)
ex owner/admin
Furious's Avatar
man forget the spreader, i use a large set of grips to compress the caliper, works just fine without buying unnesscary tools. however i realize this is your first brake job on the bimmer, so maybe i retract my previous statement and say get the tool. the guys who have done the brakes on your car a few times know how and what needs to be done
Old 03-23-2006, 07:10 AM   #12 (permalink)
tomctx's Avatar
Never screwed up a brake job yet. At least in the last 30 years. If you have the right tools, fine. If not, other things can be used. Actually, if you have a "c" clamp laying around, it works better than screwdriver.
Old 03-23-2006, 10:35 AM   #13 (permalink)
ex owner/admin
Furious's Avatar
agreed, done properly , youll never have any major issues, the brake job is easily one of DIY projects that gives you a sense of a job well done, because its usually considered a big job and the good thing its quite simple once you do it once
Old 03-23-2006, 08:15 PM   #14 (permalink)
uber e36's Avatar
uber e36 is an unknown quantity at this point
Send a message via MSN to uber e36
try www.bimmerdiy.com for some articles on how to...
Click signature for pictures:
Need some Real Estate Advice? www.gracehomes.com
uber e36 is offline   Reply With Quote
Old 03-23-2006, 08:20 PM   #15 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Word.
What also works really well is a large clamp. Clamp spin. spin spin done.
Watch for the brake fluid
Squeeling New Brakes Ljk619 3-Series (E46, E90) 6 07-08-2005 01:31 PM
Brakes Steinkek 3-Series (E36) 20 05-26-2005 11:11 AM
2001 330i Brakes? zach 3-Series (E46, E90) 2 12-09-2004 05:42 PM
Steering Shaking With And Without Hot Brakes zanick 3-Series (E46, E90) 3 10-26-2004 11:02 AM
do your brakes squeak? GnarlyCow 3-Series (E46, E90) 12 09-22-2004 08:03 PM
