Originally posted by bimerguyCW@Jul 10 2005, 08:41 PM For those who have the Peake scan tool...does it do more than the ol' stomp test codes and the 2-pins for resetting? [snapback]361361[/snapback] |
It sure does. I have two 328's and I use it at least every couple of weeks. BMW's are notorious for the check engine lights coming on. This little gadget resets the check engine light and also points in a direction for troubleshooting. The code book will actually tell you which valve,switch,sensor etc to look at first. I would highly recommend it. It has saved alot of troubleshooting time and a buck or two from the local beemer stealer....
