Dodgy Windows - BMW Forum - BimmerWerkz.com
Old 04-04-2006, 08:55 AM   #1 (permalink)
Ronanom is on a distinguished road
Dodgy Windows
The electric windows get caught, stop and go back down every time I try to close them...
Means I gotta close them bit by bit.
Do I need a new window motor or anything?
Ronanom is offline   Reply With Quote
Old 04-04-2006, 09:07 AM   #2 (permalink)
e36surge's Avatar
Got this from the link below it. Found it when I was looking for my door striker problem. Some people try changing the switch first but... I don't think that works... I've seen another write-up somewhere else as well but I can't seem to find it.
Anyhow check the link at the bottom. If you go through it thoroughly there are a number of possible solutions.
"famous window problem:
many people have window problems with e36 when their windows roll up or down by half an inch at one time.
the window motor has motion sensor inside which takes info from magnetic ring that is on motor shaft. for some reason this ring dislocates and sensor gets no info so motor drive circuit thinks its stuck.
all you have to do is to open motor and relocate this ring. on sedan it can be done without taking window mechanism apart ( and drill rivets) on coupe you have to take mechanism on table.
magnet ring is marked red and red arrow points toward its place where its have to be"
http://forums.bimmerforums.com/forum...d.php?t=238468
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
Old 04-04-2006, 09:15 AM   #3 (permalink)
Thanks,
Will check it out
Old 04-04-2006, 09:38 AM   #4 (permalink)
mehumming's Avatar
mehumming is on a distinguished road
Send a message via AIM to mehumming Send a message via Yahoo to mehumming
controller & sensors
sounds very involved.
window positioning sensors?
do they allow your windows to open a little when closing your doors and then close window fully upon closed door position???
yeah silly me i just read the posts and that should be the case
mehumming is offline   Reply With Quote
Old 04-04-2006, 04:42 PM   #5 (permalink)
Da Prophecy is on a distinguished road
On my passenger window the automatic roll up will often stop and roll down an inch or so but if I manually hold the window switch in the up position it works correctly. Do you think this is the magnetic ring problem or something else?
Da Prophecy is offline   Reply With Quote
Old 04-04-2006, 05:19 PM   #6 (permalink)
I found this video of the problem I'm having. It was posted on another forum but the thread seemed to be dead.
Anyone know the fix for this?
http://media.putfile.com/window51
Old 04-19-2006, 07:59 AM   #7 (permalink)
jcy0001 is an unknown quantity at this point
hi i have a similar problem when i pres the window to go up it stops a quarter of the way up then i pres up again it stops again half way up then i pres up again it stop 3/4th the way up but if i keep my finger on the up button it goes all the way up while im pressing it anyone?
jcy0001 is offline   Reply With Quote
Old 04-19-2006, 08:15 AM   #8 (permalink)
hey mine is very similar to the video too just not as bad
Old 04-19-2006, 06:37 PM   #9 (permalink)
ridikuledind's Avatar
ridikuledind has a little shameless behaviour in the past
I have the same problem, its been doing it for a year...I would really like to fix it. used:
<span style='color:red'><span style='font-size:14pt;line-height:100%'><span style='font-family:Geneva'>&quot;Were coming for you&quot;</span></span></span>
ridikuledind is offline   Reply With Quote
Front Power Windows In All Window Mode paraglider 3-Series (E46, E90) 2 11-16-2004 07:51 AM
Electric Windows llcoolam 3-Series (E36) 4 07-07-2004 07:37 AM
Power Windows studio945 3-Series (E46, E90) 4 01-18-2004 06:03 PM
One-Touch Windows Not Working Doc_CJ 5-Series (E12,E28, E34, E39, E60) 2 06-19-2003 12:14 PM
