Do The Plugs Really Matter? - BMW Forum - BimmerWerkz.com
Old 05-16-2005, 07:03 AM   #1 (permalink)
bpowers's Avatar
bpowers is an unknown quantity at this point
Having a lot of difficulty with my 318ti, bought Peake Research Code Reader -- no help. Anyway, I got to thinking over the weekend (as I was changing the spark plugs on my motorcycle), that perhaps it's the plugs. The reason I overlooked the plugs (my car idles slightly erratically 5-10 minutes after start-up, and also does not run well -- seems as if it's not running on all 4 cylinders, sluggish, more substantial engine breaking when you let off the gas, etc.) was because I changed them last November and car ran fine; however, I used Champion SP's. I know I've read on here that people swear that you must use OEM plugs. Is that true/would it make sense to spend the $45 to get OEM plugs to see if this is the case? I'm having trouble swallowing that a new set of plugs would foul after only a couple months, but is that why there's a substantial proce difference?
Thanks for those of you who weigh in!
bpowers is offline   Reply With Quote
Old 05-16-2005, 01:25 PM   #2 (permalink)
thesoprano's Avatar
thesoprano is an unknown quantity at this point
Send a message via AIM to thesoprano
my mechanic swears up and down on the OE plugs - he won't put anything else in. If he finds those Bosch platinum things, he chucks them.
<img src='http://www.bartspace.com/mtech.jpg' border='0' alt='user posted image' />
<span style='color:red'>RIP 1992 E30 325i Convertible M Technic</span>
<span style='color:blue'>1996 E36 328iC</span>
thesoprano is offline   Reply With Quote
Old 05-16-2005, 01:35 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
E36s and BMWs in general are very picky about spark rate and temp. The distributorless ignition takes only a certain range of spark for lack of a better word... so OEM is the best bet... fix that problem and move on and see if it helps out a bit.
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 05-16-2005, 04:06 PM   #4 (permalink)
Avlany's Avatar
Avlany is an unknown quantity at this point
Send a message via ICQ to Avlany
I would say, try Bosh Platinum +2 (not +4).
Dont piss me off. I am running out of places to hide the bodies
<img src='http://members.dslextreme.com/users/avlany/images/BMW%20banner.gif' border='0' alt='user posted image' />
Avlany is offline   Reply With Quote
Old 05-16-2005, 06:13 PM   #5 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
[snapback]344983[/snapback]
my +4's got fouled up after about 20k miles. so its possible to foul them up pretty quickly, although I have been messing around with spark/fuel management alot :P
at any rate, i just switched to oem copper ones and noticed no difference in idle/revvability compared to when i initially put in the +4 platinums.
autohausaz.com is a great place to get discount bmw stuff
they have EVERYTHING bavauto.com does but usually cheaper... and for people in arizona (like me) they're local!
oem coppers for my vehicle were like 1.50 / ea. through them (dealer wanted 5)
Old 05-17-2005, 02:47 PM   #6 (permalink)
bpowers's Avatar
Thanks everyone for the advice. I'll order some OEM's. In the mean time, I did out a new set of plugs in yesterday (non-OEM), but no help. When I took my old (<2,000 miles on them!) plugs, I noticed a lot of soot around the base on all 4 and a lot of build up, so something's not right.
Old 05-17-2005, 05:16 PM   #7 (permalink)
nukeduster's Avatar
Originally posted by bpowers@May 17 2005, 11:47 AM
Thanks everyone for the advice.* I'll order some OEM's.* In the mean time, I did out a new set of plugs in yesterday (non-OEM), but no help.* When I took my old* (<2,000 miles on them!) plugs, I noticed a lot of soot around the base on all 4 and a lot of build up, so something's not right.
[snapback]345289[/snapback]
the idle problems mixed with extra soot on plugs your injectors are probably leaking.
Old 05-17-2005, 05:26 PM   #8 (permalink)
BImmerN2B's Avatar
BImmerN2B is an unknown quantity at this point
What about Iridium plugs?
BImmerN2B is offline   Reply With Quote
Old 05-17-2005, 07:18 PM   #9 (permalink)
ex owner/admin
Furious's Avatar
dont bother with iridium plugs, they burn too cold for BMW use, they are really only a good application for Forced induced applications.
honestlly plugs DO matter very much. and use OE plugs or a suitable replacement such as bosch +2 or beru etc
Old 05-23-2005, 11:22 AM   #10 (permalink)
bpowers's Avatar
Originally posted by nukeduster+May 17 2005, 04:16 PM--><div class='quotetop'>QUOTE(nukeduster @ May 17 2005, 04:16 PM)</div><div class='quotemain'><!--QuoteBegin-bpowers@May 17 2005, 11:47 AM
[snapback]345335[/snapback]
[/b][/quote]
Do you mean that the injectors are leaking gas? Could this be from build up/clogged injectors?
Spark Plugs For 535i ben_t 5-Series (E12,E28, E34, E39, E60) 3 01-12-2005 04:07 PM
What plugs? (1984 318i) mdaitc 3-Series (E21, E30) 1 06-20-2004 09:39 AM
E36 Spark Plugs BEX 3-Series (E36) 1 02-09-2004 04:25 AM
