DIY for rear bearing anyone? - BMW Forum - BimmerWerkz.com
Old 07-13-2007, 08:40 PM   #1 (permalink)
Kissner's Avatar
Car: 1998/BMW/M3
Kissner is on a distinguished road
Send a message via Yahoo to Kissner
Anyone have any tips or DIY's for replacing the rear bearing in my M3? I've done it once before but it was not such a smooth process, just wondering if anyone has a website link or something to help me out. Thanks
Kissner is offline   Reply With Quote
Old 07-17-2007, 09:58 PM   #2 (permalink)
Ljk619 is an unknown quantity at this point
Seeing as you've done it once, then next time should go a little smoother. Of course I'm not saying that it'll be easy. I did the rear bearing on my 318 a little over a year ago, not sure if it's the same, but even while having all the equipment (I'm a mechanic), I still had a little trouble the first time. Never had to do it a second time, yet, so can't really tell you (since I don't remember) how hard it's going to be.
The only advice I can give is to mark the alignment points, either with white-out or a scribe. Cause as far as taking everything apart, once I got the gist of it I had no problem, just that I forgot to mark the alignment and when I got it all back together the rear toe was way off. You may need to use a press or a lot of hammering, but that's not a problem compared to aligning the rear wheel again to the right specs.
Sorry if that's not much help, but like I said it's been a while since I last did mine.
///M The most powerful letter in the alphabet
Ljk619 is offline   Reply With Quote
Wheel bearing replacement DIRTE30 3-Series (E21, E30) 2 08-11-2006 02:29 PM
Center Bearing Problem JoeMadoo 3-Series (E21, E30) 15 08-08-2006 09:21 PM
Where to buy Center bearing Slow325i 3-Series (E21, E30) 4 11-06-2005 01:22 AM
Throw-out Bearing Question. Damon 3-Series (E36) 9 03-08-2005 02:40 PM
