DIY HID install inside ellipsoids - BMW Forum - BimmerWerkz.com
Old 05-18-2004, 02:11 PM   #1 (permalink)
Defector
El Presidente's Avatar
To install the new euro assemblies you will first need to remove the NA spec headlights. To begin, you will need to remove the plastic peice in between the headlights. It is held in place by 6 screws, lovingly circled here:
The two on the sides also have clips that will need to be pryed out. Then lift up the panel and push it toward the rear of the car, and it will slide out of place.
Clip things:
The next step is to remove all the bulbs and the sidemarker. It is held in place by a tab, gently press on it while applying forward pressure and it will come loose. You will now have access to the 5 8mm bolts that hold the headlights on. Two are hidden here:
The other 3 are on the top. You will want to use a 19mm wrench or something to hold the plastic nuts with while you undo the bolts; these are what position the headlight.
When undoing the bolts on the inside, be VERY careful not to drop it. I did, and it took awhile to fish out.
Also, I suggest you use a socket screwdriver. If not, you will need to use multiple extensions.
By now you should've gotten one light removed. Now it's time for another plastic bag to hold your screws and beer.
Old 05-18-2004, 02:16 PM   #2 (permalink)
Defector
Hella 6000K H7 HID kit. These are the contents of the package: 2 HID bulbs, ballast, connectors, mounting bracket, 3M double sided tape, and sheet metal screws.
Clearly, the back door of the housing must be modified to allow the HID bulb and connector to fit through. The instructions said drill a 23mm hole. I eyeballed it with a dremel. The best thing I found to do was to make lateral cuts using a cutting blade and making a square, then using the sander to smooth it into a circle. There is small circle alread on the cover to use as a guide.
[img][/img]
Now we can fit the bulb and wires through the hole. Seat the bulb and clip it in place with the retainers. Then, plug the red wire with a spade on the end into the positive connection that would originaly go on the standard light. Plug the black one into the ground connection.
Re-attach the dust cover and use a thick gob of silicon sealant to keep out moisture.
Now, put the ellipsoids in the car. They are bigger than the NA spec, and will require some wiggling, but they will fit. Plig your factory lowbeam into the lowbeam adapter that came with your ellipsoids, and do the same for the highs. Now, plug in all the wires coming out of the HID light, and find a place to mount the ballast. I used the double sided tape and moutned one on the washer fluid resevoir, and the other on a peice of the chassis where the snorkell used to be (also debaffled this afternoon).
Make sure you're screws are secure and you should be good to go. Replace your fuses to 15A, and start them up. Leave it on for 5 minutes before turning it off the first time, and behold:
Old 05-18-2004, 02:19 PM   #3 (permalink)
camnipotent's Avatar
camnipotent is an unknown quantity at this point
Send a message via AIM to camnipotent Send a message via MSN to camnipotent
Nice, very nice. I hope to do the same soon.
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>1998 BMW 323is Coupe, Black
Manual
18&quot; M3 Hyper Silver Rims
2 12&quot; Rockford Fosgate Subs; Sealed
1.0 Farad Capacitor
800 Watt 2-Way Rockford Fosgate Amplifier</span></span>
camnipotent is offline   Reply With Quote
Old 05-18-2004, 03:51 PM   #4 (permalink)
Super Moderator
dutchbmw's Avatar
It's a very good example for people who want doing the same
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 05-18-2004, 05:55 PM   #5 (permalink)
That's a much better sig, Prez.
Manual
1.0 Farad Capacitor
Old 05-18-2004, 06:11 PM   #6 (permalink)
Defector
yeah, it was overdue for an update. Been waiting for these things to come in though.
Old 05-18-2004, 06:13 PM   #7 (permalink)
I didn't realize you had a push start. How much do those things cost and how hard is install?
Manual
1.0 Farad Capacitor
Old 05-18-2004, 06:26 PM   #8 (permalink)
Defector
They are $60 at pep boys. There is much cheaper method though. I did a DIY on it. It's in the FAQ area. The most expensive thing I bought was a sticker.
Old 05-18-2004, 08:37 PM   #9 (permalink)
Live Fast. Drive Faster.
buuhh99's Avatar
buuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond repute
Send a message via AIM to buuhh99
i like it
buuhh99 is offline   Reply With Quote
Old 05-18-2004, 09:42 PM   #10 (permalink)
kamikazinyc's Avatar
kamikazinyc is an unknown quantity at this point
Yo prez did you turn the projectors? So is not aiming at the oncoming cars.
It's nice and bright now wait till you swap the projectors.
DREMEL is South Africa Engineer's best friend
<span style='color:blue'>HID all the way </span>
kamikazinyc is offline   Reply With Quote
Old 05-19-2004, 01:24 AM   #11 (permalink)
Defector
im lazy. Unless people flash me I'll leave them how they are.
Old 05-25-2004, 07:39 PM   #12 (permalink)
uber e36's Avatar
uber e36 is an unknown quantity at this point
Send a message via MSN to uber e36
Prez,
I thought the Euro Ellipsoids were H1? Yours is H7?
Click signature for pictures:
Need some Real Estate Advice? www.gracehomes.com
uber e36 is offline   Reply With Quote
Old 05-25-2004, 11:44 PM   #13 (permalink)
Defector
they are. Mine are H7 though. Don't know why other than its because they arent OEM.
