Dirty Fuel Filter - BMW Forum - BimmerWerkz.com
Old 02-09-2005, 09:55 PM   #1 (permalink)
mmclaren is an unknown quantity at this point
I just had mine changed and my mechanic told me it was filthy andbadly needed a change along with the oil filter.. How can you tell usually when your fuel filter is dirty, i cant tell on MPG because i have only just got the car. So i am unable to compare it with previous driving, and also my speeds and accelerations depend on how work is going
mmclaren is offline   Reply With Quote
Old 02-10-2005, 10:40 AM   #2 (permalink)
YoungExec728 is an unknown quantity at this point
The easiest way to tell is your MPG and driving performance. If you just got the car it is difficult to tell, but you should do a full inspection of the car and replace and fix what you can since you don't know the car history.
<img src='http://memimage.cardomain.net/member_images/9/web/741000-741999/741934_9_full.jpg' border='0' alt='user posted image' />
JC Chip * Cosmos Racing CAI * UUC System U * UUC Underdrive Pulleys * Fan Delete * UUC Sachs Stage 4 Suspension * Sway Barbarians * Racing Dynamics Front strut bar * X-Brace * Front Camber Plates * UUC TME * BBS 18x8.5 * 235/40/18 Yokohama AVS Sport * F&amp;R Zimmerman X-Drilled Rotors * SS Brake Lines * Rouge RSM w/enforcers * Clears all around * SilverStars * Pioneer Avic N-1 * Pioneer 6 Disc Changer * JL 450/4 and 1000/1 Amplifiers * 2 JL 12&quot; W6V2 * Diamond Audio Hexs 6.5&quot; in kick panel * MB Quart Premiums 4&quot; in Rear * Infinity Kappa 3.5&quot; in door * Batcap 400 * Optima Yellow Top
YoungExec728 is offline   Reply With Quote
Old 02-10-2005, 03:15 PM   #3 (permalink)
mostwired is an unknown quantity at this point
You can tell when it's dirty if you take the fuel filter off and put it under water tap and see how bad it would flow. Then again, you can only see it when you take it off. Replace fuel filter every 2 years at least. It's only 20 bucks (OEM)... And you can do it yourself easily.
mostwired is offline   Reply With Quote
Old 02-10-2005, 05:12 PM   #4 (permalink)
frank3 is an unknown quantity at this point
[snapback]289303[/snapback]
Everything I've read on this makes it seem like it's not replaced that easily...certainly not compared to many cars where the fuel filter is in the engine compartment.
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 02-10-2005, 07:06 PM   #5 (permalink)
well its replaced now
i had a 318i engine with 220k and a leaking head gasket, changed the motor instead of fixing the gasket, then had all hoses, changed, new gaskets on the engine "30k's on the engine" new fuel filtre, new spark plugs, new belts gearbox oil changed, and umm thats about it
Do u think i will notice really much emprovement driving it, i was happy enuff with the performance while it was at its worst, "i dont think they are as slow and useless and everyone comments on"
Do post-1994 E36 need fuel filter changed, ever? Delmarco 3-Series (E36) 13 08-24-2006 01:39 PM
Fuel Filter Issues dsstultz 3-Series (E21, E30) 6 04-12-2005 11:07 AM
Changing The Fuel Filter hocuzanden 3-Series (E36) 13 12-11-2004 08:45 PM
whisling sound at fuel filter javieruz 3-Series (E21, E30) 2 04-12-2004 10:17 PM
