Differential Fluid - BMW Forum - BimmerWerkz.com
Old 06-06-2005, 02:14 AM   #1 (permalink)
BMN247 is an unknown quantity at this point
Hi, I've heard you need to change ur diff fluid. I've read up on how to replace it and all but just wanted to know what it is and how it affects ur car and how to know if your runnig low on the stuff. I'm thinking of getting it done soon so would like to see how much it should cost for the mechanic to get it done. I'm from Australia.
CHeers!
BMN247 is offline   Reply With Quote
Old 06-06-2005, 09:13 AM   #2 (permalink)
93 325i's Avatar
The diff fluid basically lubricates the gears in the rear end. The drive shaft connects to the diff and the diff is what turns the wheels in rear.. If you have never changed it before it would be good maintainence on your part to have it done. A shop will prolly charge you an hour labor..
Complete mod list and pics:
My 1993 325i
Old 06-06-2005, 05:35 PM   #3 (permalink)
B_w.'s Avatar
Car: turbo e36
B_w. is an unknown quantity at this point
it helps prevent wear and tear. its just like engine oil.
turbo 2.8
cp pistons, eagle rods, gt35r, tec3
B_w. is offline   Reply With Quote
ATF oil? sanjose 5-Series (E12,E28, E34, E39, E60) 3 02-01-2009 01:35 AM
What engine ,tranny and differential fluid i should use in my 89 325i Slow325i 3-Series (E21, E30) 2 11-03-2005 02:42 AM
Changing Auto Transmission Fluid billB 5-Series (E12,E28, E34, E39, E60) 8 10-11-2004 09:12 PM
Differential Groaning noise (FIXED!) shield 3-Series (E21, E30) 0 09-12-2004 04:56 AM
Rear differential fluid yogi799 3-Series (E46, E90) 1 10-23-2003 10:01 PM
