| I replaced both of my power windows in my car. I also removed the power windows in my friend's 325.
you may need to add some grease to the window tracks, you may also need new plastic slides to fit into the tracks, just possibilites. If the window is making a lot of noise, its possible the window needs to be adjusted, it dosen't necessarily mean that the motor is shot.
The best thing to do is to take off your door panel so you can see whats going on, then move the window up and down, you should be able to figure out the problem by watching it move. There are several screws that adjusts the path of the window.
It may just be in a bind.
__________________ ____\_________/____
<u>/|OO| [llllll][llllll] |OO|\</u>
<u>| o |llllllllllllllllllllllllll| o |</u>
My sh*t is not disco. Thank You.
<img src='http://home.insightbb.com/~shahabm3/wsb/media/1063900/site1013.jpg' border='0' alt='user posted image' /> |
