difference in early 92 E36 front suspension - BMW Forum - BimmerWerkz.com
Old 03-17-2004, 10:25 AM   #1 (permalink)
miatawnt2b is an unknown quantity at this point
I have a early 92 325is. The build date of the car is 2/92, so I believe that the front struts and such are different on my 325is than lets say one built after 6/92. Can someone confirm this?
Please tell me what the difference is. I am very confused. Are my struts the same as an e30?
Jim
miatawnt2b is offline   Reply With Quote
Old 03-17-2004, 10:26 AM   #2 (permalink)
Andrewsd1985's Avatar
Andrewsd1985 is an unknown quantity at this point
Send a message via AIM to Andrewsd1985
Not sure what the difference is but I know they aren't the same as the later e36s. Maybe its e30 suspension.
PRESIDENT OF THE OVER 10 YEARS OLD AND UNDER 100K MILES CLUB
1993 325i 5spd
Benfer Performance Intake
M-tech Pedals and Shiftknob
Bavarian Auto Floor Mats
Wheelskin Steering Wheel Cover
Panasonic Head Unit
Euro Projector Lights w/ black Housing
Black Housing Clear Corners
Dinan Chip
MORE TO COME!!
<img src='http://plaza.ufl.edu/dunna/Pictures/banner.jpg' border='0' alt='user posted image' />
Andrewsd1985 is offline   Reply With Quote
Old 03-17-2004, 10:43 AM   #3 (permalink)
I'm not sure if your model was the first month/year production E36. If it was, the front struts have tabs for strut mounted sway bars like the M3 design as compared to the later models which had control arm mounted front sway bars. The strut mounted front sways are more efficient in reducing body roll and overall it makes the car handle better. The ride is more harsh and puts more stress on the struts. BMW changed this on later models because they realized that their customers preferred comfort over handling so they changed the design to the control arm mounted sways. Just for your own info, a thinner strut mounted sway bar is stiffer and more efficient than a thicker control arm mounted sway.
I am not aware of any other differences although they have different part numbers, all suspension on E36's are interchangable.
Bry
Old 03-18-2004, 10:57 PM   #4 (permalink)
Doogle325's Avatar
Doogle325 is an unknown quantity at this point
Send a message via AIM to Doogle325
thanks for the super explanition AUTOTECHNICA, I too have an early 92 and were looking for that same answer....where were you when I posted that question????
Sooooo...it looks to me like I have that better suspention ....well... for my purposes ...thanks man!
Doogle325 is offline   Reply With Quote
Old 03-23-2004, 06:46 AM   #5 (permalink)
Doogle325's Avatar
this brings up another question...........will I have to get special sway bars or will any e36 bars work??????
Old 03-23-2004, 02:18 PM   #6 (permalink)
Any E36 sway bar will fit, but inorder to have them balance properly, you should be looking for sway bars made for M3's. Check to see whether or not you have a strut mounted front sway bar, or a control arm mounted front sway bar.
If you use a set of sways meant for the control arms and attach it to your front strut, you'll end up with an very stiff front end (lots of understeer).
I'm not positive which production dates. But I'm sure it's something like late '91 to early '92 models.
Bryan
Old 03-23-2004, 05:09 PM   #7 (permalink)
Doogle325's Avatar
i have a 92 with prod date of 7/91. So therefore I should be looking for M3 swaybars??????? Would our sponsor or Bav Auto insure that I get the right part for my needs?????
Old 03-23-2004, 06:18 PM   #8 (permalink)
I'm not sure if companies make aftermarket strut mounted sway bars for non M3 E36's. But you can call the company to check.
Anyways, it's not hard to check whether or not the front sway bar is connected to the strut or the control arm. Just have a peak under the car. You don't even need to jack it up.
Bry
Old 03-24-2004, 09:42 AM   #9 (permalink)
Check on understeer.com, they actually have a conversion for your car for like $100 it allows you to use m3 suspension parts, or atleast that was my understanding.
1993 325i 5spd
Panasonic Head Unit
Dinan Chip
MORE TO COME!!
Old 03-24-2004, 09:55 AM   #10 (permalink)
They already have the strut mounted sways which is the same as the M3 setup.
The M3 weld-on conversion brackets are only for the late 92-99 models with control arm mounted front sways.
Old 03-24-2004, 01:57 PM   #11 (permalink)
Laxiepoo's Avatar
Laxiepoo is an unknown quantity at this point
Doogle, got any pics? I'll check my 92 325is when I get home today - where can you find out your build date?
Laxiepoo is offline   Reply With Quote
Old 03-24-2004, 02:48 PM   #12 (permalink)
Doogle325's Avatar
ill snap a few and have them up here in the morning. Im gunna pullthe tire so I can get a couple of good clear shots of the suspention. as for the build date, youcan find it in the drivers side door well on a sticker.
Old 03-24-2004, 09:37 PM   #13 (permalink)
Laxiepoo's Avatar
Found mine - 03/92 (same month and year I got my driver's license - this car was made for me =)
I'll check my struts tomorrow - got home after dark and didn't feel like breaking out the flashlight.
Old 03-25-2004, 07:10 AM   #14 (permalink)
Doogle325's Avatar
heres the pics...I snapped them this morning.
Old 03-25-2004, 07:16 AM   #15 (permalink)
Doogle325's Avatar
whatsup guys ........sorry about that F'd up post, and the [SIZE=7]Huge [SIZE=1]pic..... Im not sure how to get it smaller. Im gunna try it again with some other shots I took.
WTB: E36 M3 front bumper AboysE36 OEM Parts 0 09-16-2005 07:25 PM
E36 Suspension Work, Want To Upgrade Suspension? victorgallas Product Reviews 8 02-08-2005 08:21 AM
Fs: E30 325ix Front Suspension Parts WOSBY Classifieds Sell & Buy 0 10-13-2004 12:38 PM
