I could be wrong, but i think the 's' comes with wider and/or larger rims and tires, and painted side skirts and front bumber. Thats about the only difference i'm aware of.
It is hard to expect us to answer a question correctly when we do not have all the information. US and Canada models never used the m40 engine on the E36, so I assume you are outside of that region.
The m40 engine was used on 318i sedans through 1993. The 318is (again, "is" simply denotes coupe) was built with the 1.8 m42 engine through 1996, and with a 1.9 m44 engine afterwards.
Location: San Diego, CA or West Sacramento, CA or Davis, CA
Car: E30 325i & E36 325i
i have heard of a 4 door e36 318is... i didnt believe the girl but she had her father check the vin. and it checked out. i want to get pictures and such soon hopefully. anybody else hear of this?
There were sport model 2 and 4 doors, but in the USA e36 range 'is' denotes 2door. In all other model ranges (e30, etc) the 'is' means sport.
In europe is means sport, as there were both 318/325/328i coupes and sedans with sports models being denoted with 's'.
Obviously bmw further mixed things up with using different engines under the same name, and using faux naming conventions (like 323i which actually uses a 2.5L engine but was named differently for political reasons to further the 2.5l single vanos engine from the 2.8l dual vanos 196hp 328i vehicle..also bmw historically always makes models with at least a '5' between each model... 318/325 were produced concurrently.. 323/328 were produced concurrently... 330/325 were produced concurrently.. 325i/330i / 328ci/335ci (more then 5)... etc etc. i guess 5 is a satisfying number)
this was all off the top of my head at 2:30 in the morning, but im pretty sure its mostly accurate
The main differences in Europe and probably in US and Canada are the following:
318i M40:
- 115HP
- 8 valves
- 1 camshaft
318iS M42/44
- 140HP
- 16 valves
- 2 camshafts
That is why You see different engine in Your car. The cylinder head and cylinder head cover is bigger than 318i. There must be place for all those things.
You have different petrol so all engines produce for US have lower compression.
This explains the differences between my car and my brother's. I've heared that 318is is 16 valves with double camshafts. But in all the forums, the guys just say that 318i means 4 doors and 318is means 2 doors which didn't really convince me.
When I used to have E30 before, I saw some cars with "is" exetension and I was told they're with "sports" package. This means that BMW should follow the same convention for E36.
