desperatly need help ASAP...car has power but no ignition. - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 04-01-2010, 11:36 PM Thread Starter
Calevra18 is on a distinguished road
Exclamation desperatly need help ASAP...car has power but no ignition.
So I have recently replaced the belts and oil with oil filter and my car was running very well, then it started to overheat because I was letting it run for a minute to work the coolant through the lines so i turned it off, but now it wont start I have taken the key completely out but its still acting like the key is in and its turned to the on position. I still have lights and all the power running to the car but cant turn it off or start it..... Please if you have ANY hints please help.
Calevra18 is offline
post #2 of 4 (permalink) Old 04-02-2010, 12:50 AM Thread Starter
Add on.
I also forgot to mention when I try and turn the key it will go fully on but there will be no clicking sound or sound of any kind....It acts like I am trying to start it without the clutch pressed in. But when I bring the key back to off and take it out the radio and all the other things stay on....also the key doesnt come out unless I turn it to the off position like normal and it doesnt spin completely around it stops like it supposed to so from what I have read I dont think its the tumblers...
post #3 of 4 (permalink) Old 04-04-2010, 08:39 PM
darkhorse737's Avatar
Quoted: 2 Post(s)
something went wrong in the electrical side of the ignition switch ...
locate your starter relay and jump the wires to the starter... or apply a 12 volt line to the starter solenoid to verify. if it starts,
darkhorse737 is offline
post #4 of 4 (permalink) Old 04-04-2010, 09:54 PM
gscp19842003 is on a distinguished road
maybe not sure tho could be anything
So after asking around a little I got some info could mean the the ecu to a dive on you or could simply be the relay for the accessories. But more commonly then not it's ur key the chip may have somehow gotten damaged so use a spare once if u have one and c if that works, if u don't have one open the key and make sure the chip is clean canned air spray otta do it.
gscp19842003 is offline
ignition locked/cut wires under car khmigga 3-Series (E36) 3 02-20-2009 05:16 AM
Desperatly Need Help! New E36 Owner aryan98 3-Series (E36) 7 02-19-2009 04:56 PM
E12 Ignition Wont Shut Car Off DennisT 5-Series (E12,E28, E34, E39, E60) 2 06-28-2005 02:21 PM
ignition switched Power points under the hood Zq-8_dawg 3-Series (E36) 3 07-24-2004 12:40 PM
