Debaffle DIY and performance change - BMW Forum - BimmerWerkz.com
Old 05-18-2004, 01:49 PM   #1 (permalink)
Defector
El Presidente's Avatar
EDIT: Detailed instructions below.
Now, after doing it on my car, there is a much more noticeable grumble in the engine and it pulls much easier and quicker at higher RPMs. I had a viedo to upload, but it won't let me. I'll work on that. Pics in a few minutes.
Old 05-18-2004, 01:53 PM   #2 (permalink)
Defector
Baffle:
Debaffled:
Old 05-18-2004, 02:03 PM   #3 (permalink)
camnipotent's Avatar
camnipotent is an unknown quantity at this point
Send a message via AIM to camnipotent Send a message via MSN to camnipotent
So you just cut it out?
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>1998 BMW 323is Coupe, Black
Manual
18&quot; M3 Hyper Silver Rims
2 12&quot; Rockford Fosgate Subs; Sealed
1.0 Farad Capacitor
800 Watt 2-Way Rockford Fosgate Amplifier</span></span>
camnipotent is offline   Reply With Quote
Old 05-18-2004, 02:05 PM   #4 (permalink)
Defector
There are tabs you can press on, and it pops out. You can cut it out aswell.
Old 05-18-2004, 03:47 PM   #5 (permalink)
Super Moderator
dutchbmw's Avatar
Someone said the air box is glued together? How did you open it?
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 05-18-2004, 05:38 PM   #6 (permalink)
skawful's Avatar
skawful is an unknown quantity at this point
Send a message via AIM to skawful
i am still not understanding how to do this on my 325
DAMNIT
anyone wanna do a diy for the 325... or help me?
V_v
<img src='http://img259.imageshack.us/my.php?image=sig8hw.jpg' border='0' alt='user posted image' />
skawful is offline   Reply With Quote
Old 05-18-2004, 06:01 PM   #7 (permalink)
Defector
Skaw, Im going to do this in baby steps. If you can't get it out after this, I will honestly be worried about your ability to operate an automobile.
1. Open driver door.
2. Pull hood latch.
3. Walk to front of car, stick hand uner hood and release the secondary catch.
4. Look at airbox.
5. Note the two bolts next to the airbox by the cruise control module.
6. Take off the bolts. I think they were 8mm.
7. Move cruise contol out of the way.
8. Pull up on the tabs holding the aribox lid on, then push the retainers back.
9. Move the lid out of the way and prop it up against something so it doesn't go back into place and get in your way.
10. Remove air filter
11. Frimly grasp box, and cajole it out of the engine bay.
12. Look inside the box. Pretending the box was still insde the car, look to the left. You will see a small circle.
13. Take a screwdriver, and poke inside the circle.
14. This will break it loose.
15. Remove from box.
16. Reinsatll everything in the reverse order.
Old 05-18-2004, 06:42 PM   #8 (permalink)
Defector
If the 325 airbox is signicantly different take a pic and we can figure out how it is done.
Old 05-18-2004, 06:53 PM   #9 (permalink)
skawful's Avatar
thanks, but i have a 325 not a 318...
Old 05-18-2004, 07:07 PM   #10 (permalink)
Defector
yes, and again, if the 325 airbox is significantly different take a pic. It still uses a similar snorkel, so the baffle should be eaually similar.
Old 05-18-2004, 08:04 PM   #11 (permalink)
skawful's Avatar
sry when i posted that you hadnt posted yet (i didnt refresh)
here are the pics
Old 05-18-2004, 08:10 PM   #12 (permalink)
skawful's Avatar
my airbox hmmm
Old 05-18-2004, 08:12 PM   #13 (permalink)
skawful's Avatar
behind the airbox, what im thinkin is holding it on but im not sure...
the snorkel (?) inside the airbox... is very different from the 318..?
its leading into the actual intake not from the fan...
sorry if i am stupid about this, we all gotta start somewhere
Old 05-18-2004, 09:19 PM   #14 (permalink)
mikester328's Avatar
mikester328 is an unknown quantity at this point
Send a message via AIM to mikester328
Hrm, so I could use the instructions above on debaffling a 318 airbox also?
mikester328 is offline   Reply With Quote
Old 05-18-2004, 10:46 PM   #15 (permalink)
Kevin325i's Avatar
FOR AT 325i Follow these instructions:
1. Remove the airbox from the car. There's two silver clips on the MAF sensor. Then there is two nuts to the right side of the airbox (when you're facing the windsheld standing at the front of car) There's a duct on the front of the airbox you need to take off, wiggle the rubber tube of the other outlet to the engine. Also there is a temperature probe in the back of the airbox.
2. Once you've got the airbox out take a look INSIDE. Up where the outlet to the engine is there's an extra plastic piece. This is the baffle. Stick a screw driver in the seem between it and the rest of the airbox and pop it out.
3. Ok, so now you've got the damn thing out of the airbox right? Well no. Now you realize that there isn't enough room to take the baffle out. The solution is to cut a small gap in the baffle with a dremil tool. Then sneak it out the inside of the airbox. Or you could just it the whole thing into 2 pieces.
4. Reinstall your stuff, you're done.
Kevin
P.S. I let the inlet from the front grill off only because it was sitting on the other side of the car and I didn't see it till I closed the hood
Kevin (President TBEA)
