Dash Brake Light - BMW Forum - BimmerWerkz.com
Old 10-11-2004, 06:04 PM   #1 (permalink)
Byron320i is an unknown quantity at this point
Send a message via MSN to Byron320i
This is probably a stupid question but...i recently replaced my brake pads, but the new pads didnt have the connection for the brake light sensor, so i just cable tied it up but the light on the dash wont go out.
so any ideas?
Byron320i is offline   Reply With Quote
Old 10-11-2004, 10:26 PM   #2 (permalink)
Fadec40 is an unknown quantity at this point
I'm sure you put the correct pads on. The cable sensor has a "u" shaped edge and should just press into the center of the brake pad edge.
Fadec40 is offline   Reply With Quote
Old 10-12-2004, 12:01 AM   #3 (permalink)
Defector
El Presidente's Avatar
I assume you replaced the brake sensor anyway? If its still the old cable, it will still be on. Also, the pads should have a U in the center, and the new sensor will clip into place.
Old 10-13-2004, 05:11 PM   #4 (permalink)
no, the pads i put on are pattern parts so they dont have the grove,do i have to connect the two wires together or ground them to the car body?
Brake Light Check HoFF 3-Series (E21, E30) 2 07-13-2005 06:43 AM
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
HELP, e36 brake light curcuit fault code theogill 3-Series (E36) 4 08-27-2004 07:48 AM
After tail-light upgrade, left brake light is gone mostwired 3-Series (E36) 3 11-26-2003 05:13 PM
