Damned SRS Light. - BMW Forum - BimmerWerkz.com
Old 10-08-2009, 01:59 PM   #1 (permalink)
acid86's Avatar
Car: 1992 Bmw 318is (e36)
acid86 is on a distinguished road
Send a message via MSN to acid86 Send a message via Yahoo to acid86
Angry Damned SRS Light.
So a while back I removed my steering wheel to get to my instrument cluster. In doing so, i removed the airbag. Ever since, the damned SRS light won't quit blinking.
I've tried, leaving the battery off for an extended period of time, unplugging and re-installing the airbag, all to no avail.
It's not an EXTREEME GUYS I NEED HELP, but it's sure as hell annoying. Anyone got any advice?
"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones." - Albert Einstein
acid86 is offline   Reply With Quote
Old 10-08-2009, 02:32 PM   #2 (permalink)
Kai
Kai's Avatar
Car: E39 Alpine White 528i, E34-Sold.
Kai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud of
Send a message via AIM to Kai
You will probably have to take it to BMW and have it reset. I have had work done on the steering column and the light is now on, hopefully because it needs reseting and not because the system is actually not working, but I was told I would have to take it to BMW to get it looked at.
Kai is offline   Reply With Quote
Old 10-08-2009, 02:55 PM   #3 (permalink)
acid86's Avatar
Well, hell. Hasn't some one figured out a way to "reset" that light too, kind of like you can use a wire and bridge the service and oil change lights? There are -no- bmw dealers near me. It's over 2 hours drive to the nearest one.
Old 10-08-2009, 03:12 PM   #4 (permalink)
Kai
Kai's Avatar
I mean if you can figure out how to do it yourself then go for it, but BMW doesn't release all of it's codes to independents and I am pretty sure SRS system codes are some they don't, so an independent most likely wouldn't know what the problem is or what to do other than to check the fuses. If nothing else and you are sure it is just the light and the system is working then put a picture over it, that is what I have done for the time being.
Old 10-08-2009, 05:24 PM   #5 (permalink)
acid86's Avatar
And I thought I was the only ghetto modder on here.
Awesome.
Old 10-08-2009, 10:07 PM   #6 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Awesome.
Buy this & call it a day...............I've used mine a few times already & it has paid for itself!
BMW Airbag (SRS) Tool - Scan and Reset Airbag Light by Peake Research
jb
Old 10-11-2009, 02:30 AM   #7 (permalink)
BrianXE36's Avatar
Car: '97 E36 328i
BrianXE36 is on a distinguished road
I look at it this way, because I've got the same issue. You can buy that neat little tool and reset the light when it comes on, OR you can actually go and get them properly serviced and pay just as much as you would have to buy that little thing. 9 times out of ten, its a bad sensor or an accidental trip as your airbags really don't do anything other than sit there and wait to explode in your face. I'm choosing the service route simply because its a used car that i have no idea what the people before me did with it. Lets hope it works out.
Originally Posted by johnnybayonne View Post
I eat, sleep, & breathe BMW
BrianXE36 is offline   Reply With Quote
Old 10-11-2009, 11:46 AM   #8 (permalink)
I actually saved money, because the BMW Dealers in this area charges $130.00 an hour for labor.......& the trip there just to wait around.......this tool just does not clear the code, but it also tell's you what's wrong.......example: if it is the driver's side seat belt sensor, it will tell you that.....
also, he basically needs to clear the SRS light, because he disconnected his steering wheel without disconnecting his neg. cable on his battery.....this tripped the light.
But.... if you do not feel comfortable fixing it yourself, then maybe bringing it to a dealer is the best thing to do.
jb
2000 posts.....Yay! I can has a custom title!
Old 10-13-2009, 11:44 AM   #9 (permalink)
acid86's Avatar
So, here's the only problem with that tool. It says its' for 94-00... My e36 is a 92...
Old 10-13-2009, 12:11 PM   #10 (permalink)
Found this..... Pre-1994...if you are willing to give it a shot, links below: tool from Germany they say it costs about 49 euros which = about $65.00
I just ordered 4 from Germany from Zymexx
SRS Reset tool - Bimmerforums - The Ultimate BMW Forum
Zymexx Fahrzeugtechnik - Service Resetter BMW SIR3 digital GZ6005
jb
SRS Light Jimw 3-Series (E36) 4 02-26-2009 11:54 PM
SRS light on its_tc! 3-Series (E46, E90) 2 10-09-2006 06:22 PM
SRS light. Ivan 3-Series (E36) 4 09-27-2006 11:58 PM
SRS Light cloaked95 3-Series (E36) 1 09-06-2006 08:15 AM
Srs Light Help jsdreed 3-Series (E36) 3 03-12-2005 04:41 PM
