Damn Airbag Light! - BMW Forum - BimmerWerkz.com
Old 11-25-2004, 01:49 AM   #1 (permalink)
Rich328's Avatar
Rich328 is an unknown quantity at this point
Send a message via MSN to Rich328
my air-bag light has come back on!
i had the seat occupancy mat changed about 5 months ago - and the damn lights come back on.
I'm selling the bmw - had enough !
Rich328 is offline   Reply With Quote
Old 11-25-2004, 08:50 AM   #2 (permalink)
theogill is an unknown quantity at this point
Send a message via MSN to theogill
Sucks, tho I had this problem and needed to change both sensors in the belt receptacles or whatever they're called--not cheap, but not a ballbuster either. No problems since.
98 328i, black/black, manual, canadian sport pkg, ECIS intake, koni sport adj's, dinan springs, oe/oem clears.
Considering: tms shark,M 17" wheels, larger sway bars.
theogill is offline   Reply With Quote
Old 11-25-2004, 09:39 AM   #3 (permalink)
Fadec40 is an unknown quantity at this point
Seat belt tensioners common cause.
Fadec40 is offline   Reply With Quote
Old 11-25-2004, 12:00 PM   #4 (permalink)
the most common fault with E36 air bag lights is the wiring to the seat belt pre-tensioners, the fault is in the block connector under the seats. You can buy a repair loom that has the wire from the tensioner to the conector a modified concector and wiring to the floor loom. To fit this unbolt the seat cut the wiring just above the carpet and SOLDER in the new loom it just plugs into the tensioner be careful on the passenger side not to cut the ocupancy mat wiring you normaly don't need the tensioners themselves
Old 11-26-2004, 07:51 AM   #5 (permalink)
Eggrolled211's Avatar
Eggrolled211 is an unknown quantity at this point
[snapback]237186[/snapback]
yeah mines on too...getting annoying...but I don't get this cutting wire stuff... ghead
<img src='http://l00062.myspace.com/00062/50/89/62019805_m.jpg' border='0' alt='user posted image' />
Eggrolled211 is offline   Reply With Quote
Old 11-26-2004, 11:53 AM   #6 (permalink)
123NotIt's Avatar
123NotIt is an unknown quantity at this point
Whatever you do, don't cut the red wire or it will explode!!!! Or was it the green wire?
<img src='http://sonny.ramsay.us/m3_footer.jpg' border='0' alt='user posted image' />
123NotIt is offline   Reply With Quote
Old 11-26-2004, 12:51 PM   #7 (permalink)
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
my light blinks for a while then stays on. I figured it was maybe the service point where I need to take it to the dealer and have the system inspected and checked for regular service.. I didn't know there was a wire problem. Guess i'll have to check this out
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' />
bimmerfan620 is offline   Reply With Quote
Old 11-26-2004, 02:11 PM   #8 (permalink)
[snapback]237139[/snapback]
I had the same problem, I changed the tenioser once the problem was gone ($200) about 10 months later the same problem occurs, i say fuck it.
Old 11-27-2004, 07:05 AM   #9 (permalink)
[snapback]237822[/snapback]
"White you're right, red you're dead"
Airbag firing circuit mdimbler 5-Series (E12,E28, E34, E39, E60) 0 10-31-2005 11:51 PM
Airbag problem versace 3-Series (E46, E90) 2 09-19-2005 10:43 AM
Airbag Light Rodrigo 3-Series (E36) 12 04-02-2005 07:52 PM
FS: Airbag unit for BMW E36 3-Series & Z3 cars DINAN 3 Classifieds Sell & Buy 2 08-14-2004 02:46 PM
airbag woobiee Bimmer Talk/Motorsports Talk 4 10-03-2003 09:56 PM
