Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 03-26-2006, 09:08 PM   #1 (permalink)
thekid's Avatar
Car: 95 M3
Photos: 0
Cruise Control Question...
Today I had the fun experiance of finding out that for some reason braking does turn off my cruise control. The result was that the car tried to speed up while I was trying to brake and sped up a lot when I released the brake. Where should I start looking? If it was electrical I would think that the whole system would not work... am I correct?
Old 03-27-2006, 03:39 AM   #2 (permalink)
Administrator
Furious's Avatar
Photos: 0
mm half correct electrical problems can cause so many problems, especially when the item your fixing is completely dependant on electronics as apposed to mechanical. if you were to step on the brake yes your cruise should shut off completely, but if you started to speed up, im a bit stumped, i would certainly get the issue resolved by a professional, as electrical problems can really be tough.
but.. as i re-read the thread, im wondering if your saying that the your car suddenly started to speed up dramatically when in cruise control mode... if this is the case than you might have pushed the cruise lever a certain way, either forwards or inwards, which is also a function to accelerate, matter of fact it could be to continue to accelerate untill you provide more input to the vehicle (i.e-braking or shutoff)
R.I.P Steve aka fast 6
Old 03-27-2006, 09:33 AM   #3 (permalink)
thekid's Avatar
Car: 95 M3
Photos: 0
I do not believe that I could have... I was quite confused when it happened the first time, so I decided to try it for a second time to make sure and it definately is the case that braking does not shut off the crusie system and that I was in no way touching the lever.
I really just want to get an idea of what it could be before I take it any where. I'm at college, so I don't have a mechanic here and I am very sceptical of all mechanics until they have proven that they are fair and honest people.
Old 03-27-2006, 10:18 AM   #4 (permalink)
drz
master of his domain
drz's Avatar
Car: e36 2.8i; e46 zhp
Photos: 0
^^ The signal from the brake pedal may not be getting to the cruise control system. Try this: does pressing the clutch pedal shut off your cruise? If it does, then your problem is related only to your brake pedal, and you can rule out your cruise control not working. A lose connection could be the culprit. All in all, you can always go without cruise control.
Turkey Fleet Bond Holder
Old 03-27-2006, 01:08 PM   #5 (permalink)
Administrator
Furious's Avatar
Photos: 0
yeah its tough to find a mechanic who you can trust.. good luck dude, im a bit lost for thoughts
Old 03-27-2006, 01:43 PM   #6 (permalink)
thekid's Avatar
Car: 95 M3
Photos: 0
Yeah, I usually do not use crusie control but I was feeling particularly lazy yesterday and had a longer drive than I usually do (5 1/2 hours instead of 4 1/2). I didn't think to try to clutch... I'll try the clutch the next time I am out.
Old 03-28-2006, 05:40 PM   #7 (permalink)
e36surge's Avatar
Photos: 0
e36surge is an unknown quantity at this point
I have a mechanic friend at BMW here in Montreal. I've asked now a second time if he's seen many e36s with faulty cruise control modules. His reply has been no and has mentioned faulty break pedal switches. I posted this info on another thread. Now the link is not about your particular problem but it does show you where the brake pedal switch is.
This may not be your problem but it may help you narrow the possibilities.
http://www.users.fast.net/~slafredo/...clutch_pedal/#
<img src='http://urban4x4.ca/e36surge.jpg' border='0' alt='user posted image' />
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Daily Driver
vB code is On
Cruise control actuator (servo) Cambridge 5-Series (E12,E28, E34, E39, E60) 3 11-26-2005 11:34 PM
Cruise Control stracer 3-Series (E36) 4 09-25-2005 10:00 PM
Cruise Control Stutter Bunny Capricorn 5-Series (E12,E28, E34, E39, E60) 1 09-09-2005 09:55 PM
cruise control not working espestice1 3-Series (E46, E90) 0 12-31-2003 08:47 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
