Cruise Control Not Engaging - BMW Forum - BimmerWerkz.com
Old 10-08-2003, 01:57 PM   #1 (permalink)
valiant1 is an unknown quantity at this point
My cruise control isn't working - should I take it to a mechanic? The fuse is not blown. What does this usually cost to fix?
I heard that the dealer has to "code" the unit if it's replaced or it won't work? Is this true?
Valiant
valiant1 is offline   Reply With Quote
Old 10-08-2003, 02:28 PM   #2 (permalink)
318i-Bmw is an unknown quantity at this point
Are you in 5th gear?
318i-Bmw is offline   Reply With Quote
Old 10-08-2003, 07:45 PM   #3 (permalink)
Hamann 325i is an unknown quantity at this point
Can you use cruise control in 5th gear?
Hamann 325i is offline   Reply With Quote
Old 10-08-2003, 10:23 PM   #4 (permalink)
Does it matter what gear I'm in? According to the User's manual, I just need to be going over 22mph.
Old 10-08-2003, 10:24 PM   #5 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
well i can drive my dads car in fifth and be under 22 mph...the car jumps around but i can do it....its like BAUT...BUAT...BUAT....BUAT...
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 10-09-2003, 09:51 PM   #6 (permalink)
Defector
El Presidente's Avatar
did it work before? Sometimes its just a bitch to engage.
Old 10-10-2003, 06:12 PM   #7 (permalink)
Recently got the car. I'm sure it worked at one time. I guess I'll take it to the dealer and have them check it out and go from there.
Old 10-21-2003, 12:03 PM   #8 (permalink)
Cruise control problem was the clutch swtich. It's an electrical switch down by the clutch pedal. $14 at the dealer. It required adjusting by my mechanic but replaced the clutch switch and works fine.
Cruise Control stracer 3-Series (E36) 4 09-25-2005 09:00 PM
Cruise Control Stutter Bunny Capricorn 5-Series (E12,E28, E34, E39, E60) 1 09-09-2005 08:55 PM
Cruise Control Noise alanrw 3-Series (E21, E30) 0 10-29-2004 12:49 PM
Adding Cruise Control To 320i?! alexb75 3-Series (E46, E90) 0 09-28-2004 06:28 PM
cruise control not working espestice1 3-Series (E46, E90) 0 12-31-2003 07:47 PM
