Cricket Noise? - BMW Forum - BimmerWerkz.com
Old 08-12-2003, 01:25 PM   #1 (permalink)
cardio is an unknown quantity at this point
Just recently when I brake semi-hard a cricket type noise comes from the front of the car ( seems like its comin through the air conditioning ) any suggestions on what the problem could be?
cardio is offline   Reply With Quote
Old 08-12-2003, 01:26 PM   #2 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
How 'old' are your brakes?
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 08-12-2003, 01:36 PM   #3 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
well you might need new brake pads.....or it might just be dirty or something.....
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 08-12-2003, 09:30 PM   #4 (permalink)
BlackTape's Avatar
BlackTape is an unknown quantity at this point
Send a message via ICQ to BlackTape Send a message via AIM to BlackTape Send a message via MSN to BlackTape Send a message via Yahoo to BlackTape
PADS.
<img src='http://www.satchmo.com/cashmoney/btymers.jpg' border='0' alt='user posted image' />
<span style='font-family:Impact'><span style='font-size:21pt;line-height:100%'><span style='color:red'> GANGSTA Tape</span></span></span>
BlackTape is offline   Reply With Quote
Old 08-13-2003, 10:34 AM   #5 (permalink)
I think its the air conditioning, cuz when i turned off my car today it made that noise and i wasn't braking.
Old 08-13-2003, 11:30 AM   #6 (permalink)
morph's Avatar
morph is an unknown quantity at this point
Send a message via AIM to morph
i'm having an issue w/ my AC. the compressor may need to be replaced. i have sort of a cricket noise/whistling when the ac is on. there is no relation to braking though. my mechanic says that's between $250-700 to get fixed. it's been a while since i talked to him about it, but there is a chance it could be really simple and actually possibly be as low as $120 to fix. but if they have to replace several parts and do a flush of sorts it would be more expensive as it is a time consuming ordeal.
try this: start your car, stay parked and roll down your windows. turn on your ac. if after about five seconds you do not hear the cricket noise, toggle your ac off and then on again. wait another five seconds and if you don't hear it...it might not be your ac.
when you hear this noise are you driving and your windows are up or down? my ac can only be heard with the windows down.
well...that's my experience. i hope it helps.
<img src='http://home.earthlink.net/~thefurthestpoint/bimmer.jpg' border='0' alt='user posted image' />
morph is offline   Reply With Quote
Old 08-13-2003, 11:44 AM   #7 (permalink)
Retired administrator
triggrhaapi's Avatar
if it's only when you're braking, it's brakes. It most likely means that there's just a little bit of grit in your pads somewhere and it makes a little chirpy noise. Nothing to get concerned about. if it's your A/C, then the chirpy noise is the belt slipping, so you have a) a loose belt which could be caused by a failing tensioner, I don't remember if the A/C is auto tensioning or not, I'll have to consult mr. Bentley on that. b ) Your a/c compressor is siezing and the chirpy noise is the belt slipping because the compressor won't turn the way it used to.
Addicted to Speed Since 1997
Old 08-14-2003, 11:50 PM   #8 (permalink)
EXtech's Avatar
You need to focus on the belts and the tensioners. Check the a/c belt tensioner pulley. That's probably what you're hearing. Also check the belt for cracks or missing chunks.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
What the HELL is making this NOISE???? bimmer_boy 3-Series (E36) 28 01-18-2008 07:15 PM
Ticking Noise From Engine Clint_M 3-Series (E36) 9 11-07-2004 11:02 AM
cricket noise (not a/c, not brakes) kerki 3-Series (E46, E90) 2 06-02-2004 04:27 PM
loud noise - including clicking tsinghbmw 3-Series (E36) 6 06-01-2004 02:25 PM
