Couple of warnings about E36 - BMW Forum - BimmerWerkz.com
Old 06-29-2004, 02:52 PM   #1 (permalink)
steve325IS's Avatar
steve325IS is an unknown quantity at this point
Thumbs down
Okie...
Some of you may know about the water pump using a plastic impeller. I found out the hard way. Almost home and all of a sudden smoke, steam comes from under my hood. Im like holy shit! Only 1 block from house so I keep on going, as I drive onto my driveway, it gets worse. I get out, look behind me on the street and theres *lots* of water following me to my driveway. Looked under the hood and no coolant. Had to get the car towed to mechanic and turns out, the plastic impeller failed-broked, causing the radiator to bust and some hoses. Radiator probably busted at weak point,old age, but this did cost me alot to fix. 99% of people talked to say the plastic impeller caused this. No coolant flow, heated up, and boom..problems.
Anyway, it turns out its a common problem. Have the pump replaced or end up SOL when it fails.
Heres a good article I found on a wiring problem that shorts out...causing electric failure
Wiring Problem of the E36
This is just a heads up..its better to be safe than to shell out money on things you could have avoided
<img src='http://img.villagephotos.com/p/2004-6/749643/closer.jpg' border='0' alt='user posted image' />
steve325IS is offline   Reply With Quote
Old 06-29-2004, 03:35 PM   #2 (permalink)
I heard that it was just the 92-95 E36 that had the water pump problem. Is this true? It was an item that I plan on replacing very soon, but if 96 through 98 weren't affected then I won't replace it.
Old 06-29-2004, 04:15 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Mine was not plastic..... I've taken it off before... and I'm possitive it was never changed... and I have a 97.
1997 E36 M3 1990 E30 325i
Old 06-29-2004, 04:32 PM   #4 (permalink)
kamikazinyc's Avatar
kamikazinyc is an unknown quantity at this point
Mine 94 changed mine dealers don't sale the plastic ones anymore.
DREMEL is South Africa Engineer's best friend
<span style='color:blue'>HID all the way </span>
kamikazinyc is offline   Reply With Quote
Do post-1994 E36 need fuel filter changed, ever? Delmarco 3-Series (E36) 13 08-24-2006 01:39 PM
NEW E36 Rear Axel Bearings jroozee OEM Parts 0 11-06-2005 09:33 PM
Parting out 1995 E36 318Ti Manual Transmission bacustoms420 Wheels and Tires 0 10-12-2005 12:52 AM
my comparison e30 vs e36..I own both Trob 3-Series (E21, E30) 4 10-04-2005 04:27 PM
