Couple of simple questions - BMW Forum - BimmerWerkz.com
Old 12-07-2005, 04:27 PM   #1 (permalink)
1faste36 is on a distinguished road
1. I have a 94' 325is and the heated seat on the passenger side turns on then turns right off like 5 seconds later. I push the button on the counsel and it turns red just like it is suppose to but then i turns right off in a few seconds. Anyone know what is causing this?
2. Where is the light bulb for the lights switch? Where you turn on my lights is not illuminted when i turn my lights on. Does anyone know where i find the bulb for that so i can replace it?
1faste36 is offline   Reply With Quote
Old 12-07-2005, 05:13 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
First one.... I'll get back to you... I'll look it up in the Bentley...
Second one.... which light are you speaking of? There is no light bulb for the light switch it self...
Les
1997 E36 M3 1990 E30 325i
Old 12-07-2005, 05:14 PM   #3 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
dont know about #1 but #2 check pelicanparts.com or just call them...
Old 12-07-2005, 05:25 PM   #4 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
First one... The entire system consists of this
You have two fuses in the front distribution box...
Fuse No. 23 and Fuse No. 4
Check No. 4... as both power sources go to a unloader relay... so if the sure is burnt... the other might power for a few seconds then realize it cant power everything.
The power then goes to your drivers and passengers heater switch...
It has a min/max inside of the switch... and then that power goes to the seat back heater and the seat heater... check all connections with the switch... everything.
Good Luck,
Les
Old 12-07-2005, 06:13 PM   #5 (permalink)
where you turn on the lights to my car is suppose to be illumiated like the rest of the interior of the car....that amber red color. It has not been lighitng up for some time now and i dont know how to fix it
Old 12-07-2005, 06:45 PM   #6 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Yes it is. Just make sure to check all your fuses. Since it's an insolated area i'm thinking it might jsut be a blown bulb...which ive never personally heard of in that location.
Old 12-07-2005, 09:12 PM   #7 (permalink)
bimmerboy328i's Avatar
bimmerboy328i is an unknown quantity at this point
Send a message via AIM to bimmerboy328i
The bulb in the light switch burns out quickly since it is on all the time. Whenever the car is on, it is on.
PN: 61138360844
You will need to remove the light switch and disconnect it from the light switch harness. Im trying to find my diagram....
- 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD -
bimmerboy328i is offline   Reply With Quote
Old 12-07-2005, 09:13 PM   #8 (permalink)
The PN (#18) above is for the bulb.
Old 12-07-2005, 10:07 PM   #9 (permalink)
Yeah too bad they didn't use an LED in there....
Mike
Hamfisted is offline   Reply With Quote
Old 12-07-2005, 10:17 PM   #10 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
Bmw didnt know what an led was prior to late model e46's. They are slow to get with the program on some technologies. Case in point.. cassette players. I never checked, but I wouldnt be surprised if you could still get one in an e90.
to answer the first question, the heating element may be burned out, the circuit does a self test, sees that it isnt making a full connection and turns itself off again as a safety measure.
Old 12-12-2005, 09:12 PM   #11 (permalink)
Replaced with LED ....
I went out and looked at my kids car and it was burned out too. I temporarily replaced it with a Sylvania 2721 bulb (stock type) but I ordered about ten #74(they replace the stock 2721 bulbs...) white LED replacement from these guys at Super Bright LEDs online....
http://www.superbrightleds.com/cgi-b...=5344473.18313.
I also ordered some 3022-4w LED "Festoon" bulbs
to replace the glovebox, courtesy and license plate bulbs. They were cheap enough I figured I'd go ahead and do as many as I could find. I even ordered a handfull of the #194 LEDs for sidemarker and various other uses.
You can always find uses for those little bulbs. They run cooler and last forever.
Mike
Old 12-12-2005, 09:15 PM   #12 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Interesting... a LED for the old lights.... thats news to me...
Les
Couple of Questions rborak318iS 3-Series (E36) 5 10-02-2005 08:21 PM
Couple Questions alexlikh87 3-Series (E36) 13 05-10-2005 11:49 PM
Just got my new car and have a couple of questions gaudi 3-Series (E46, E90) 3 07-15-2004 05:46 PM
couple questions 2Crucial 5-Series (E12,E28, E34, E39, E60) 19 03-13-2004 05:06 AM
Couple of questions please Rayzorman1 3-Series (E46, E90) 2 11-30-2003 03:05 PM
