Couple Problems.. - BMW Forum - BimmerWerkz.com
Old 05-05-2005, 08:02 PM   #1 (permalink)
92_325i is an unknown quantity at this point
alright, so i've had my car for a few months now and starting a couple months ago my windows started to get temperamental. they would work most of the time, but then sometimes they wouldnt no matter what i did. it slowly started going the other way, to where they would usually not work. and now, they just flat out dont work. i've put a new lock switch on it. i've played with the wiring. i've checked the fuse. i'm completely baffled on this one. any ideas?
on to the A/C problem...back in october or november i had noticed that there was no a/c belt on my car when i bought it. not a big deal, it's cold outside (then it was). just went to finally get a belt on there and got it on, and the car wouldnt start. the a/c compressor must be rusted or something because it wont turn. any ideas on unsticking that, or do i just have to buy a new one?
and the fluid leak....i am leaking brake fluid, and bad. it's not coming from the brake components. after leaving the car sit for a while a puddle will build up under the center of the car right behind the oil pan. i am not sure where this leak would be coming from. also, it only leaks enough so that the fluid level reaches the line for minimum, which causes my clutch pedal to go directly to the floor.
any help you guys can give me will be greatly appreciated. thanks.
<a href='http://www.cardomain.com/id/jordan92bmw325i' target='_blank'>My 1992 325I</a>
<a href='http://www.cardomain.com/memberpage/461648' target='_blank'>My 1989 Nissan 240sx</a>
<a href='http://www.cardomain.com/member_pages/view_page.pl?page_id=724529&cat=10&val=1&page=1' target='_blank'>My girls' 1998 Camaro</a>
92_325i is offline   Reply With Quote
Old 05-06-2005, 01:58 AM   #2 (permalink)
mathieu134 is an unknown quantity at this point
I don't know about your AC and windows, but I had the same problem for the leaking brake fluid. Your clutch takes it's fluid from the same place your brakes do. I'm very sure that it's the clutch cylinder (the one attach to the clutch), the fluid is leaking in the bell housing. Take the cylinder off, push the pedal (clutch) if the fluid is leaking from it, change it. It's about 90 bucks (CAN$). Tell me if it worked!
mathieu134 is offline   Reply With Quote
Old 05-09-2005, 09:28 PM   #3 (permalink)
alright, another problem came up tonight. i was driving home tonight, and hit a bump and a light came on in my instrument cluster and i dont know what it is. it's the little red circle with the little dashes on the sides. any ideas on this??? sorry, i dont have the manual and i've never seen a light like that.
Old 05-09-2005, 09:29 PM   #4 (permalink)
Avlany's Avatar
Avlany is an unknown quantity at this point
Send a message via ICQ to Avlany
Brakes
Dont piss me off. I am running out of places to hide the bodies
<img src='http://members.dslextreme.com/users/avlany/images/BMW%20banner.gif' border='0' alt='user posted image' />
Avlany is offline   Reply With Quote
Old 05-10-2005, 09:18 AM   #5 (permalink)
alright. thanks. it was a false alarm. the fluid was just getting low. everything is back to normal now. but now i still have the window and AC problem.
Couple Problems aotiko 3-Series (E36) 11 05-16-2005 10:33 PM
Couple Problems... E30M20b25 3-Series (E21, E30) 10 04-24-2005 04:53 AM
Couple Of Problems With '84 318i JLew 3-Series (E21, E30) 2 02-02-2005 02:29 AM
a couple small problems cronus10 3-Series (E46, E90) 0 07-10-2004 06:20 PM
A couple problems 007ben Bimmerwerkz.com Site Help 10 04-07-2004 06:53 AM
