Originally posted by bad man working@Mar 17 2005, 12:44 PM If they open from the inside handle but not the outside you can adjust the out handle by remove the gromet in the door and slacking the screw [snapback]313517[/snapback] |
Can you explain how to fix that a littel better, mine does they same thing. It opens from the inside, but not from the outside.
