» Sponsors
» Sponsors
Old 07-03-2009, 07:27 PM   #1 (permalink)
Rekless56's Avatar
Car: 93' E36 325i
Photos: 0
Rekless56 is on a distinguished road
Question Cooling Problems!?!?!?
How you doing..i replaced the radiator, fan shroud, fan, and coolant tank on my 93 325i...but for some reason i still have a coolant leak...i have checked all the hoses..they are tight..so im stumped...Any ideas????
Rekless56 is offline   Reply With Quote
Old 07-03-2009, 07:31 PM   #2 (permalink)
Photos: 0
Do you have a way to get it pressure tested?
Old 07-03-2009, 08:03 PM   #3 (permalink)
Rekless56's Avatar
Car: 93' E36 325i
Photos: 0
No...Could that be the problem???
Old 07-03-2009, 09:23 PM   #4 (permalink)
Photos: 0
It could be a way to find the leak.
Old 07-03-2009, 11:13 PM   #5 (permalink)
Rekless56's Avatar
Car: 93' E36 325i
Photos: 0
How would i go about doing that??
Old 07-03-2009, 11:19 PM   #6 (permalink)
Photos: 0
You may need a garage to do it; they are equipped and know where to hunt the most likely leaks.
Old 07-04-2009, 08:32 AM   #7 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 735i
Photos: 0
Put a fluorescent dye in the coolant system then you should be able to see the leak.
marti5 is online now   Reply With Quote
Old 07-04-2009, 11:45 PM   #8 (permalink)
Rekless56's Avatar
Car: 93' E36 325i
Photos: 0
thanks alot guys..i fixed the leak but now i have a new problem..the car wont stop overheating..i replaced the thermostat today thinking that would fix it...No go..Any other ideas guys???????????????
Old 07-05-2009, 12:02 AM   #9 (permalink)
Photos: 0
Bad water pump?
Old 07-05-2009, 04:12 AM   #10 (permalink)
marti5's Avatar
Car: E38 1997 735i
Photos: 0
Viscous coupling or you have air in the system, if you roll up a news paper and stick it in the fan and it stops its the viscous coupling as for bleed ing the system correctly always do this from cold, fill up with engine off and A/C on max heat but fan at lowest setting. fill and bleed you may have to do this several times, if this fails as Whitshark says possible waterpump.
Old 07-06-2009, 09:43 AM   #11 (permalink)
Rekless56's Avatar
Car: 93' E36 325i
Photos: 0
I am thinking bad water pump too...the coolant tank was full so i thought thermostat but yeah...
Old 07-06-2009, 10:30 AM   #12 (permalink)
Rekless56's Avatar
Car: 93' E36 325i
Photos: 0
how do i bleed the air out of the cooling system when i change the water pump??
vB code is On
A/C is cooling too much _cb_ 3-Series (E46, E90) 2 07-11-2007 03:08 PM
AC cooling OFF and ON jerico 3-Series (E36) 5 11-10-2006 11:18 PM
Over Cooling? liquidtiger720 5-Series (E12,E28, E34, E39, E60) 3 12-01-2004 02:22 PM
Cooling Problems Tornado 3-Series (E36) 1 06-08-2004 08:53 PM
Cooling Problems djm1313 Bimmer Talk/Motorsports Talk 0 12-31-1969 07:00 PM
