Coolant System Leak - BMW Forum - BimmerWerkz.com
Old 05-03-2005, 07:36 AM   #1 (permalink)
davlam is an unknown quantity at this point
Hi all,
My 318is ('93) has sprung a leak, driving along noticed the temp light on.. It is not the radiator or the hoses. It appears to be coming from the engine block to the left (as you face the car) and behind the thermostat housing. Only managed to have a quick look as it was torrential yesterday.
I have read in the manual (Haynes i'm afraid) that there are
cylinder block drain plugs
but there are no pictures or descriptions etc. I can feel a square headed plug of some description and close by a small hole which may or may not be missing a bung.
Anyone got any pictures etc..or help with this area of the cooling system.
I can't be more precise as the car is at my mother in laws so can't take any pics right now.
cheers,
davlam
davlam is offline   Reply With Quote
Old 05-03-2005, 02:56 PM   #2 (permalink)
If you’ve got a M42 engine there’s a common fault with a rubber seal that sit at the front of the head/block above the water pump housing, they rot away with age and the coolant leaks out of the back of the front timing cover on the exhaust side of the block. That’s the good news.
The bad news is you have remove the cylinder head to fix it..
Old 05-03-2005, 04:56 PM   #3 (permalink)
Originally posted by ""+--><div class='quotetop'>QUOTE("")</div><div class='quotemain'>That’s the good news.[/b]
<!--QuoteBegin-""
The bad news is you have remove the cylinder head to fix it.. [/quote] ghead ghead ghead
Will have a closer look tomorrow...then find someone to buy it as it's 12 years old and not worth much. In fact the private reg is worth more than the car... ghead
Old 05-04-2005, 12:05 PM   #4 (permalink)
hi,
had a closer look using a mirror and managed to take this pic..it looks quite tame here but in reality when i fill the radiator the water pours out from this area...so looks as though you were right...
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
1997 328i Coolant Leak and Maintenance Larry Horne 3-Series (E36) 4 10-15-2005 07:45 PM
The American Vs. The German billB 5-Series (E12,E28, E34, E39, E60) 83 10-14-2004 07:09 PM
Problem with the Coolant Leak RedBeemer95 3-Series (E36) 3 07-23-2004 02:53 PM
