Coolant/radiator issues - BMW Forum - BimmerWerkz.com
Old 01-11-2006, 07:55 PM   #1 (permalink)
Dactyl's Avatar
Dactyl is on a distinguished road
Send a message via AIM to Dactyl
Recently my OBC has been saying low coolant.. I've been putting it off for a while (a week or so) and today the car sputtered a little when I turned it on. Checked everything to make sure it was ok and everything checked out fine.. I thought while the hood was open I might as well add coolant. The message went away but the prev. owner explained he had to do this a couple times himself over the course of the few months he owned it. I added about 1.5-2 cups of fluid.
What I'm getting at is, are there common problems with e36 radiators or water pump/coolant systems that would cause this issue? I never notice a leak but I'm pretty sure you shouldn't need to refill coolant this often.. anyone have any input?
1994 325is M-Technic
Dactyl is offline   Reply With Quote
Old 01-11-2006, 08:56 PM   #2 (permalink)
e36surge's Avatar
It could be one of many things.
Is your rad the original? Is your water pump original? e36 common problems. I'd start with check the rad for leaks. Do a pressure test and check for leaks. If you replace the water pump get the one with the metal impeller. Check the hoses too. The fluids got to be going somewhere. Any leak marks under your car? OR you could have a faulty level sensor.
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
Old 01-11-2006, 09:45 PM   #3 (permalink)
SD318is is an unknown quantity at this point
if you are not actually loosing coolant it could be the level sensor... but you better be sure first
SD318is is offline   Reply With Quote
Old 01-11-2006, 09:47 PM   #4 (permalink)
Dactyl's Avatar
The level sensor is fine I think.. the resivior was indeed empty when i checked it
I'll look at the hoses and check for leaks, but nothing shows up on the concrete when I let it sit for a while.. when I changed the oil i noticed a lot of gunk (probably what used to be fluid or coolant) caked all over the areas near the radiator...
Edit: everything is stock.. the guy who owned it before me was rich as shit apparently, and looking at all the maintinance records he gave me, this guy probably paid near the retail price of the car getting owned by BMW dealers and mechanics for maintenance, but everything on there is original
Old 01-11-2006, 10:32 PM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Well... I agree with all of the above... but if you've had the coolant system serviced in the past month or so... with what I've found to be a common occurance with E36s is, is that it takes a few days for the coolant to fully reach every passage within the block... after a full drain service. It happens. You refill... check it daily in the morning when the car is cold.. fill to the cold line..
If the car keeps telling you that your coolant is low.. but infact your coolant level is just fine... then you have a sensor problem. Easy as that.
If you are lossing fluid.. then you should be able to know that too... as long as you can justify that your coolant system was full at a given time.
My conclusion... fill it up... if the message goes away... for a few days... and the level drops... then you start searching for a leak.
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 01-12-2006, 12:51 AM   #6 (permalink)
tomctx's Avatar
First I would make sure it's bled. Unscrew the plastic screw next to the overflow tank. Crank the car and let it warm up. turn on the heat. Add coolant until coolant comes out of the bleed hole with no bubbles. A little messy, but these cars are notorious for being hard to bleed. that way, if the light comes on again, good possibility you have a leak somewhere.
Old 01-12-2006, 12:27 PM   #7 (permalink)
93 325i's Avatar
If no leak is visiable, check under you oil cap and dipstick for a "milky" substance. The coolant could be mixing with the oil.. Also I have heard that the coolant could be evaporating therefore not leaving a trail.. I would def moniter this and if it persists look for the cause.
Complete mod list and pics:
My 1993 325i
Old 01-12-2006, 08:59 PM   #8 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
To add to 93 325i's comments, if you do find his milky substance, you have big trouble--a crack between coolant channels and oil channels.
Lindsay fan club member.
Old 01-12-2006, 11:07 PM   #9 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
^ The most common problem towards this issue is the head gasket it self....
I dont like changing those... PITA.
Les
Old 01-13-2006, 08:20 AM   #10 (permalink)
93 325i's Avatar
bfc has a DIY for the headgasket.. took the guy 30 man hours lol.. After I read it I deducted that it is well worth the $1000 to have it done by a pro. (hope i never need this tho)
My 1993 325i
Old 01-13-2006, 09:59 AM   #11 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Yea.... they take a while if you dont have the right tools.. and a couple extra hands.
Les
Old 01-13-2006, 01:21 PM   #12 (permalink)
Dactyl's Avatar
Don't think it's the head gaskets.. pics below. Any help identifying the gunk thats all over the steering column?
Old 01-14-2006, 07:59 AM   #13 (permalink)
fredo328's Avatar
fredo328 is an unknown quantity at this point
Send a message via Yahoo to fredo328
How often are you refilling? or adding? If you're adding a cup or three every 5-10,000 miles then that is normal. If you find you have to add every few hundred miles then there is a leak. Regarding the gunk in the last pic, it appears to be power steering fluid,common on our cars for the hoses from the PS reservoir to seep/leak and make a mess down there. Those hoses are right behind there, you might as well check to see if you're low on power steering (ATF) fluid too.
<img src='http://home.comcast.net/~farrieta/index_files/image001.jpg' border='0' alt='user posted image' />
<a href='http://www.328i.org/index.php' target='_blank'>328 life</a>
1998 328
fredo328 is offline   Reply With Quote
