Coolant problem - BMW Forum - BimmerWerkz.com
post #1 of 15 (permalink) Old 01-30-2009, 02:57 AM Thread Starter
zeaq's Avatar
zeaq has a spectacular aura about zeaq has a spectacular aura about
Send a message via AIM to zeaq Send a message via MSN to zeaq Send a message via Yahoo to zeaq
Coolant problem
Hello,
My car is having a coolant problem.It all starts when the car overheats and all the coolant goes through the cap.That happens when the car is parked and the engine is swicth off. So we just refill it with water and call it a day. But the problem now is the car always loss a lot of coolant.
I refill it with water up to the top level and leave it for a night. The next day I start, the OBC says “LOW COOLANT”. So I check the coolant level, it’s almost empty. Where did the coolant go? When I refill, I don’t see any water dripping below the car and I even and use it for the day. I come back and check the level, its ok. But the next day, the level would be low again. Why is that? The car has 43k Miles and it regularly service.
I actually did some googling. i found this pelican article regarding E36 coolant.
Pelican Technical Article: BMW 3-Series E36 Cooling System Flush
It says the main area I should check is: To Do list:
1) Hoses
2) Waterpump
3) The reservior
4)Radiator
5)Seal on radiator cap
6)Perform pressure test from Pro
7)Check head gasket (Also sugested by thedude60126) to check if coolant leak into the oil if does not hold pressure)
Faulty head gasket if you remove the oil cap and find some yellow murky subtance)
Today, I check the car again, There's no coolant or water in it.
But i notice a few things(shown in pics)
1) I notice there's coolant on the screw?
2)
3) Coolant on the floor
What does this indicate? Faulty cap?
thanks for the reply. I need some opnions.
My BMW 328i- AC Schnitzer Spoiler, Blaupunkt Stereo,Angel eyes(CCFL), M technik Lower Lip.
928 GTS- Stock
Z
zeaq is offline
post #2 of 15 (permalink) Old 01-30-2009, 04:11 AM
Help from over the pond
marti5's Avatar
Do you have any mayo on the oil dipstick??, as this would indicate headgasket problem.
The only time you can check the coolant level and fill on this system is when the engine is stone cold.
You say you have been filling with WATER, I hope you mean COOLANT ( water+antifreeze
as just water will do damage to the engine.
marti5 is offline
post #3 of 15 (permalink) Old 01-30-2009, 04:46 AM Thread Starter
zeaq's Avatar
^^I will do that later.
I do fill it with this as shown below
but the tank will go empty overnight so i just fill with water sometimes. I do refill it with coolant.
928 GTS- Stock
Z
zeaq is offline
post #4 of 15 (permalink) Old 01-30-2009, 04:52 AM
marti5's Avatar
So no mayo on the oil dipstick ???
marti5 is offline
post #5 of 15 (permalink) Old 01-30-2009, 06:17 AM
freestyleronli's Avatar
freestyleronli is on a distinguished road
I take it the bleed screw has been tightened accordingly - not too tight and not too loose?
freestyleronli is offline
post #6 of 15 (permalink) Old 01-30-2009, 08:27 AM Thread Starter
zeaq's Avatar
no mayo....
freestyle,
I'm not sure...but i will have it check...at the garage tomorrow and also bring for the pressure test.
928 GTS- Stock
Z
zeaq is offline
post #7 of 15 (permalink) Old 01-30-2009, 11:37 AM
marti5's Avatar
It may also be leaking from the sensor located underneath the expansion tank, this just twists approx 1/3 and then pulls out and has an 'O' ring to seal it.
Also have a good check around your waterpump.
It may be that your thermostat is not opening up, are you getting heat in the cabin?
marti5 is offline
post #8 of 15 (permalink) Old 01-31-2009, 12:27 PM Thread Starter
zeaq's Avatar
OK, today I was having a hell of an adventure
The whole country was in flood but it doesn't effect my journey. I was driving and the temperature start to rise and I stop over the road side. Yes coolant was splasing all over. I call the towing compant to pull the car to the shop. So I end up riding in the truck
The main cause is the screw shown in pics above. The seals are worn out. They change that and bleed the systme to chekc for leaks. No indication of leaks.
And I drove back to the house(45 mins), No problem so far....and I check...The coolant it's stil at its level.
So I assume it's Ok for now.
Thanks for the help guys
928 GTS- Stock
Z
zeaq is offline
post #9 of 15 (permalink) Old 01-31-2009, 12:52 PM
Quoted: 1 Post(s)
Glad to see you have it sorted!
witeshark is offline
post #10 of 15 (permalink) Old 01-31-2009, 01:11 PM
marti5's Avatar
That's great news, I will remember that one for future reference.
marti5 is offline
post #11 of 15 (permalink) Old 01-31-2009, 01:48 PM
drz
Administrator
drz's Avatar
Quoted: 1 Post(s)
drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute
They changed the screw? Or did they change the expansion tank?
drz is offline
post #12 of 15 (permalink) Old 01-31-2009, 02:43 PM Thread Starter
zeaq's Avatar
They change the screw-- Cost 8$BND= 2 pounds...including the pressure test service.
928 GTS- Stock
Z
zeaq is offline
post #13 of 15 (permalink) Old 01-31-2009, 02:54 PM
That's what happened to mine - hence my above post!
It's a good feeling when 1) The problem's sorted and 2) it doesn't cost a lot.
post #14 of 15 (permalink) Old 02-01-2009, 11:08 AM Thread Starter
zeaq's Avatar
Oh yes. I'm glad it's just as smiple screw!..not the head gasket or something expensive...
928 GTS- Stock
Z
zeaq is offline
post #15 of 15 (permalink) Old 02-01-2009, 12:10 PM
drz
Administrator
drz's Avatar
Quoted: 1 Post(s)
Cool
drz is offline
Coolant/Radiator Problem?! angilfyre 3-Series (E36) 1 01-18-2007 03:35 PM
coolant problem: (thermostat?) bimmerguy82 3-Series (E36) 5 12-05-2005 10:17 PM
Coolant Problem Slvr e39 5-Series (E12,E28, E34, E39, E60) 7 09-13-2004 10:52 PM
Problem with the Coolant Leak RedBeemer95 3-Series (E36) 3 07-23-2004 03:53 PM
