Coolant Caking On Radiator Hose - BMW Forum - BimmerWerkz.com
Old 07-29-2009, 10:35 PM   #1 (permalink)
Risiko is on a distinguished road
So very recently I noticed a little bit of coolant caking onto hoses connecting to the radiator (upper radiator neck?) on my 94' 325i. See the following photo -- any additional analysis is appreciated:
So I took the car into a mechanic and he said that I ought to be concerned about this since the radiator neck has a significant chance of cracking at some point. My cursory further research into it tells me to take him seriously (the plastic impaler situation and all).
I'm going to replace the whole cooling system (radiator and all) per his advice. I've decided to go ahead and try a DIY, even though I've never done a job that's anything like this before. But I want to make sure I am ordering all the needed parts. Using Pelicanparts.com, I found parts with the part numbers that the mechanic printed out for me. Does the following list of items sound comprehensive?:
-Bleeder Screw for Expansion Tank
-Radiator Cap
-Thermostat O-Ring
-Thermostat Housing/Cover - Aluminum
-Genuine BMW Antifreeze, 1 gallon
-Thermostat 88 Degrees
-Radiator
What else will I need/should I buy to do the job? Pelicanparts.com makes it seem like there is more to buy. Is 1 gallon antifreeze sufficient? Should I get new radiator hoses? Water pump? Water pump belt? Mounting brackets? Rubber insulators? Do I need to buy any special tools (I have a pretty comprehensive mechanical toolkit already)? Any other miscellaneous things to order? I feel like I'm going to miss at least one essential peice of the puzzle. I want to do a complete job.
I'm gonna take my time and get myself up to snuff on the DIY tutorials for the job in the meantime.
But I appreciate the help! I'll make sure to keep everyone updated with the job itself after I order the parts and they come in...
Risiko is offline   Reply With Quote
Old 07-30-2009, 11:30 AM   #2 (permalink)
Car: 1995 M3
Beerbot is on a distinguished road
Good idea to go with the aluminum housing, also try to get an all aluminum radiator. The plastic sides on the original tend to give out. They make oem all aluminum radiators, so look around. Its not a hard job to do. The radiator is pretty much just sitting in there. After everything is disconnected there are two clip tabs on either side and two mounting support bushings/ brackets on the bottom that its just sitting in. The pelican parts is a great place to go for help. Pelican Technical Article: BMW Radiator Replacement I also reccomend seeing if your car was made with a plastic water impeller on the pump. They also sell oem all aluminum replacements for that as well. Good luck!
Beerbot is offline   Reply With Quote
Old 07-30-2009, 01:23 PM   #3 (permalink)
Swift E36 is on a distinguished road
Mishimoto makes a really nice aluminum radiator, I would definitely go to an all-aluminum radiator. Way better than the plastic end tanks!
Swift E36 is offline   Reply With Quote
Old 08-01-2009, 04:23 AM   #4 (permalink)
Thanks for the heads up. But now I'm wondering if it's necessary to replace the small hose in the photo. According to the following diagram, it's the radiator and engine return hose:
RealOEM.com   BMW E36 325i Cooling System Water Hoses
If you look at the photo you see that there is a tiny bit of dried coolant on the end of it there where it attaches to the radiator. Do you think that'll be a problem or what?
Thanks again.
blown radiator hose. heartbreaker 3-Series (E36) 2 02-16-2007 01:18 PM
What is the screw called that is at the opposite side of the radiator hose? mnakao 5-Series (E12,E28, E34, E39, E60) 4 05-10-2006 05:03 PM
Replacing A Coolant Hose BYOCOM 3-Series (E36) 3 04-21-2005 03:55 AM
Coolant Hose Diagram? M5power 5-Series (E12,E28, E34, E39, E60) 0 03-21-2004 11:36 AM
Radiator leak from hose to the left delerdelarosa 3-Series (E21, E30) 5 10-24-2003 12:07 PM
