convertible front/rear window spacing - BMW Forum - BimmerWerkz.com
Old 07-06-2008, 10:50 PM   #1 (permalink)
deman70 is on a distinguished road
Just moved up from a E30 convertible to a E36 convertible (1997 328i).
The spacing of the driver side windows to too far apart and the windows do not seal well. Comparing it to the other side (which is proper), it looks like the front windows land at the same distance from the top's mid-joint on both sides of the car but the rear side window on the driver's side is just too far back. BTW: it doesn't matter if the top is up or down, the little gap is the same.
How would one adjust the rear side window to be more forward?
-rdd
deman70 is offline   Reply With Quote
Old 07-07-2008, 03:07 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Cool
check for binding at the window guide rails. binding will cause your window regulator clutch to "let go" and switch off earlier than it should...
Convertible rear window trim bmwman53 3-Series (E36) 0 06-27-2006 08:17 PM
E30 Convertible Rear Window Guides snpower 3-Series (E21, E30) 0 04-21-2005 07:32 PM
90 E30 convertible front passenger window parkerbink 3-Series (E21, E30) 3 06-23-2004 02:35 PM
convertible rear window problem verojimmy 3-Series (E36) 3 05-20-2004 09:10 AM
Replace rear window on 323i convertible getsummmmmm 3-Series (E46, E90) 7 01-21-2004 07:50 PM
