Control Arm Removal Help! - BMW Forum - BimmerWerkz.com
Old 12-02-2010, 08:47 PM   #1 (permalink)
stryker14 is on a distinguished road
To all,
I am very frustrated. I have two issues.
1. I can't get the outer ball joint to seperate from the hub. I have tried a pickle fork, With hammering, hammered the hub, broke a small puller trying to remove it. Any help?
2. How do you get to the inner ball joint nut? I can get a socket on it but no room for the rachet. I can get a stubby box wrench on it but can't get enough force to move the nut. It looks like it is not accessible from the top due to various components. What tools have others used? Any help would be greatly appreciated.
Ted
stryker14 is offline   Reply With Quote
Old 12-03-2010, 10:20 AM   #2 (permalink)
cjscopp's Avatar
Car: 2002 525i and 1995 325i
cjscopp is on a distinguished road
Recently overhauled the front suspension on our 1995 325i and did not have any trouble. A few suggestions on the outer ball joint. I used my floor jack arm as a lever to pry down on the lower control arm as I smacked the knuckle with a hammer and it popped right off. As to the inner, I used an open end wrench from the front of the car after removing the outer tie rods and just turned the nut a little at a time. It took a while but that was the only way I found to get at it. The passenger side has a little better access than did the drivers side. Be patient and the nuts will come off. The front end on these things is very simple and well engineered IMO. Aligned it with a tape measure and got it pretty close according to the alignment shop. Good luck.
cjscopp is offline   Reply With Quote
Old 12-04-2010, 08:43 PM   #3 (permalink)
Thanks for the reply, got back under there with the box wrench and got the inner nut off. Those ball joints are a real Pain!
Ted
Control Arm eferree 5-Series (E12,E28, E34, E39, E60) 6 01-28-2007 11:43 AM
Control Arm? kkevin77 3-Series (E46, E90) 0 12-03-2004 10:57 AM
Control Arm Bushings theruss1an1 3-Series (E36) 2 10-16-2004 12:30 AM
question about wiper arm removal 1994 318is ultraviolet353 3-Series (E36) 3 09-09-2004 04:24 PM
control arm bigred318 3-Series (E21, E30) 3 06-28-2004 09:09 AM
