Control Arm Bushing - BMW Forum - BimmerWerkz.com
Old 02-13-2009, 11:59 AM   #1 (permalink)
jock is on a distinguished road
Control Arm Bushing
Hi, New member with a question. Have a 99 323IS, changing control arms.Found out I need bushings. Are the bushings for a 323I and 323Is the Same. Are the bushings for E36 and E46 the same. Don't know what to buy. Your help appreciated.
jock is offline   Reply With Quote
Old 02-13-2009, 03:05 PM   #2 (permalink)
jmo69's Avatar
Car: 1998 328is 2003 325xi
jmo69 is on a distinguished road
Not sure about e36 and e46, but 323I and IS should be the same, M3 bushings are different, but can be used. Centered and offset. Bought my e36 bushings from FCP Groton and got the 2 piece polyurethane ones.
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline   Reply With Quote
Old 02-13-2009, 03:15 PM   #3 (permalink)
martyyyn's Avatar
Car: E36 325Turbo Diesel
martyyyn is on a distinguished road
323 & 323i are the same, i think its the same set up on the E36 & E46,
here s a DIY , that will help, click link below
u n d e r s t e e r . c o m
Cheers Martin
martyyyn is offline   Reply With Quote
Old 02-13-2009, 04:04 PM   #4 (permalink)
jmo69's Avatar
Cheers Martin
^^^^^ That's the one I used but didn't need the home made pusher/puller because I used the poly bushings and they went on easily.
Old 02-13-2009, 04:57 PM   #5 (permalink)
Thanks for the quick response. Think in good shape with your help. Gerry
Old 02-13-2009, 08:41 PM   #6 (permalink)
Science Roolz!
Car: 2011 Mazda2, 1990 Miata
the e46 uses different arms so I'm pretty sure the bushings are different, but like said earlier all non m e36s are the same bushing. The m3 bushings will work as well and are stiffer. The 95 m3 ones are offset and change the amount of caster. 96-99 m3 ones are centered like normal. Regardless you'll probably need an alignment after you replace them, but if you use 95 m ones you'll definitely need one. If you have any questions let me know, I've done this job more times than I can remember on e36's and e46's. If you have an autozone near you, I'd hit them up and rent a pitman arm puller makes removing the outer balljoint from the hub A LOT easier. Pickle fork is also a must. If I remember any other tips I'll let you know.
2011 Mazda2
1990 Mazda Miata
Old 02-14-2009, 08:56 AM   #7 (permalink)
martyyyn's Avatar
yes you are right its the E30/E36 are the same but not the E46,
many thanks Martin
Control Arm Bushing Help snpower 3-Series (E21, E30) 10 09-19-2007 10:54 PM
Lower Control Arm Bushing Byron320i 3-Series (E36) 2 05-30-2005 09:20 AM
Control Arms, Ball Joints, And Bushing ???s wulley1 3-Series (E36) 3 02-01-2005 08:00 AM
Bimmerworld Trailing Arm Bushing Tool culkj 3-Series (E36) 0 10-27-2004 08:46 AM
"trust arm bushing" AKA ??? Hoppy's535i 5-Series (E12,E28, E34, E39, E60) 5 05-20-2004 09:14 PM
