Confused As To What Happened - BMW Forum - BimmerWerkz.com
Old 08-28-2005, 09:17 PM   #1 (permalink)
Car: E30 318i, E30 318is, E30 M3
dvmotorsports is on a distinguished road
I was pulling into a parking lot yesterday and I had my wheel turned to the right (about 30 degrees). I stopped for a second to allow a car backing out of a parking stall to get the hell out of my way. When I engaged the clutch, my rear right tire lit up and the car wouldn't move at all. After I pulled in, I checked to see if I was hung up on the curb, but I wasn't. I have a 1992 318is. This car should never spin the tires under normanl clutch engagement.
Any ideas?
BMW Technician
dvmotorsports is offline   Reply With Quote
Old 08-28-2005, 09:57 PM   #2 (permalink)
thekid's Avatar
Was there standing water? Ice? Some chemical on the ground? The only times my tires have lit up have been when it was hailing. The car would kick to the left even under slow starts. I have no clue what it could have been unless there was something to reduce your traction either on the tire or ground.
Old 08-28-2005, 10:23 PM   #3 (permalink)
Dry as could be.
BMW Technician
Old 08-28-2005, 11:27 PM   #4 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Help a foreigner out: what do you mean by "lit up." I am guessing that your tire did not catch on fire. I am sorry I cannot be of any help. Out ouf context I gather that you lost traction. I don't want to scare you, but somthing like that could have someting to do with your differential failing on you. However, take into consideration that I am responding to a post I did not even understand in its entirety.
Turkey Fleet Bond Holder
Old 08-28-2005, 11:35 PM   #5 (permalink)
You are right. And a failing diff, was my first thought.
BMW Technician
Old 08-29-2005, 12:13 AM   #6 (permalink)
quality
Delmarco's Avatar
lit up = spun out with smoke or screech perhaps.
few things I could think up:
-Uneven tire pressure
-Uneven tire wear
-Uneven pavement..
Old 08-29-2005, 03:04 PM   #7 (permalink)
aheath's Avatar
aheath is an unknown quantity at this point
Send a message via AIM to aheath
heavy foot?
ease off the gas
aheath is offline   Reply With Quote
Old 08-29-2005, 04:00 PM   #8 (permalink)
Power Shifting
Cruzin 323is's Avatar
did you side step it by accident? and powerbraked it??
-SOLD..
R.I.P Fast 6
Old 08-29-2005, 08:51 PM   #9 (permalink)
Originally posted by aheath+Aug 29 2005, 01:04 PM--><div class='quotetop'>QUOTE(aheath @ Aug 29 2005, 01:04 PM)</div><div class='quotemain'>heavy foot?
ease off the gas
[snapback]373166[/snapback]
[/b]
Nope. Mild clutch engagement as well as application of the gas.
<!--QuoteBegin-Cruzin 323is
@Aug 29 2005, 02:00 PM
[snapback]373183[/snapback]
[/quote]
I've never even thought about powerbraking a 5 speed. That's funny.
BMW Technician
Old 08-29-2005, 11:14 PM   #10 (permalink)
Storamin's Avatar
Storamin is an unknown quantity at this point
Originally posted by dvmotorsports+Aug 29 2005, 09:51 PM--><div class='quotetop'>QUOTE(dvmotorsports @ Aug 29 2005, 09:51 PM)</div><div class='quotemain'><!--QuoteBegin-Cruzin 323is@Aug 29 2005, 02:00 PM
[snapback]373230[/snapback]
[/b][/quote]
You should try it some time.
Storamin is offline   Reply With Quote
Old 08-30-2005, 05:16 AM   #11 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
Check for oil leakage on the casing of the final drive (diff). Bad seals can cause a low oil level inside, resulting in slipping or chatter. If it doesn't happen again, I wouldn't worry about it.
Also, there could be a simpler explanation to this . . your front wheels were turned right, so the left rear wheel would be a little more weighted than the right. Or it may have been sitting on a piece of cardboard or something, and threw it back far enough that you didn't notice it. But that can be enough to get the wheel spinning.
Dudesky_E36 is offline   Reply With Quote
Old 08-30-2005, 01:03 PM   #12 (permalink)
drz
drz's Avatar
Car: zhp
My wheels have spun similarly before. I never make anything of it.
Old 08-31-2005, 04:41 AM   #13 (permalink)
obd2guru's Avatar
obd2guru is an unknown quantity at this point
Send a message via AIM to obd2guru Send a message via MSN to obd2guru Send a message via Yahoo to obd2guru
one day i was power braking my 328 and spinning my tires like a maniac had a cloud of smoke ,but suddenly i woke up.
&lt;a href=&quot;/forum/index.php?showuser=21196&quot;&gt;<img src='http://obd2guru.com/dio/obd2guru.gif' border='0' alt='user posted image' />&lt;/a&gt;
If everithing fails try the hammer. obd2? <a href='http://www.obd2guru.com' target='_blank'>obd2guru.com</a>
obd2guru is offline   Reply With Quote
Old 08-31-2005, 06:32 AM   #14 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
Go on flat ground. And redo multiple times what you did at the parkin lot and see what happens. If it happens again like it was said before go to the diff.
-Serge
theruss1an1 is offline   Reply With Quote
318i se -I AM CONFUSED. expediant 3-Series (E36) 8 12-18-2007 03:08 AM
What Happened To Spiff? german-speed-demon 3-Series (E21, E30) 0 07-07-2005 02:49 PM
Oh No, It Happened. thesoprano 3-Series (E36) 15 05-11-2005 02:19 PM
Confused Confused Confused WindowPro 5-Series (E12,E28, E34, E39, E60) 14 11-09-2004 09:19 AM
Amazed and Confused pc4now Wash & Detail 3 08-03-2004 03:52 PM
