Computer Still Saying Cylinders Misfiring... - BMW Forum - BimmerWerkz.com
Old 01-28-2005, 04:33 AM   #1 (permalink)
socalguy is an unknown quantity at this point
Problem: check engine codes saying cylinder 2 and 5 misfiring.. what could it be?
oh and it is not the valve gasket, or spark plugs--new.
So i have taken my car into the mechanic twice for the problem. He thought it could be the valve \gasket... WAS WRONG... check engine light came back on still saying cylinders 2 and 5 misfiring!
So i dont want to keep fixing things that dont need to be fixed. If anyone has had these engine codes before pleaes help me out so i know what needs to be fixed.
Thanks.
socalguy is offline   Reply With Quote
Old 01-28-2005, 01:57 PM   #2 (permalink)
pcy
pcy is an unknown quantity at this point
1. Check the Ignition coils on those misfiring cylinders. Try to swap those coils with other ones and see if the problem says with the same Cylinders and MOVES with the ignition coil.
2. Moisture in the gas tank COULD cause similar problem.
I recently had this problem. Mine turned out be the moisture in the gas tank.
My CEL light went away after driving some time with a full tank of fas and fuel injector cleaner.
pcy is offline   Reply With Quote
Old 01-28-2005, 02:00 PM   #3 (permalink)
pcy
[quote=pcy,Jan 28 2005, 02:57 PM]
</quote>
Sorry about misspellings and poorly formed sentence...
I meant to say:
"Try to swap those coils with other ones and see if the problem STAYS with the same Cylinders OR moves with the ignition coil."
Old 01-28-2005, 04:32 PM   #4 (permalink)
pcy,
Thanks for you input, i will do that this next monday.. i was thinking the same thing.
On Board computer dmonk 3-Series (E36) 9 08-29-2010 09:03 PM
can i retrofit 13 button onboard computer onto my car? träumer 3-Series (E21, E30) 4 11-01-2005 07:37 PM
Turning Computer (or Temp Display) On? Superfry 3-Series (E46, E90) 1 01-11-2005 12:30 PM
Trip computer not working in 88 735i ericesquire 1,6,7,8 - Series and Mini Cooper 0 12-10-2003 06:24 AM
