Ok i went and had my car check out the other day and got all my fluids changed (everything) and changed my spark plugs to. I asked the mechanic to do a compression check while he was working on my car. For some odd resone i dont think he did it but here is what he said. (Front to back) 173, 173, 173, 170, 170, 175. Dose these numbers look about right? And also what are the cylinder numbering order.
thanks in advance.
__________________ <span style='font-family:Times'>1994 325is 5-speed 129,000 and strong</span>
sound perfect... they're all within 10lbs of each other which is what an engine is supposed to be doing. means the cylinders are aging correctly and you'll have a ton of life left in them :P
Originally posted by jrhaile@Apr 14 2005, 06:56 PM sound perfect... they're all within 10lbs of each other which is what an engine is supposed to be doing. means the cylinders are aging correctly and you'll have a ton of life left in them :P
[snapback]332620[/snapback]
cheers to another 100k hopfully.
Originally posted by benji84@Apr 15 2005, 01:12 AM what are you guys compression numbers and milage? just courious to see whats other cars are running.
So as you can figure already, tore my engine apart. Piston rings were almost gone, sixth cylinder wall had a scrape, valve gaskets (don't know if that's the right expression) were dead, valves need work etc.
As the engine has already been torn apart I decided to port my engine head while I'm at it already.
The interesting thing is that a week before I did the compression test I dynoed my car and it produced 182hp and 162lb-ft of torque... that's normal for an engine that is 14 years old... but taking into account the shape it was in, I'm surprised
__________________ <img src='http://meph.pri.ee/~meph/sig.jpg' border='0' alt='user posted image' />
<span style='font-family:Arial'><span style='font-size:8pt;line-height:100%'><span style='color:green'><a href='http://www.clubarena.com/~bmwklubi/gallery/album32' target='_blank'>My car</a></span></span></span>
(Started as a 316... not anymore)
Custom leather interior, custom audio install, custom made bumpers, clear side and corner markers.
Custom exhaust, CAI (also custom =) )
M50B25 transplant, 325 brake system, brembo rotors, ferodo pads.
Coming:
Coilover kit, 17'' rims, lots of gauges and a few surprises.
All of mine are in the low 70s.... yours are normal... and jrhail... If I'm not mistaken.. all the values should be within 85% of the highest value.. per BMW manuals... haha...
